Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Mower will stay running but acts like its geting choked
Model # - 20016
It might be the jets in the carb but I really dont no how to clean them
  • 77 Answers
It probably needs a good cleaning. Take it off and get a can of chemtool spray (the stuff is awesome) and soak that ****** with it. Then take an air nozzle and blow it all clean,and reinstall.
Posted on Aug 10, 2009
Have onan microquiet 4000ky will not stay run without full choke has new f pump+filt Sonic clean carb Shut down solenoid operational Carb really not a serviceable item
cab jets coroided fid it and use a needle to clean it or take a paper clip and file it to an extremly sharp point that is square on sides use this to put in the jet hole lite pressure and twist it dont open the size of the brass jet more then 10%or it will flood
Jul 15, 2017 | Cars & Trucks
My riding lawn mower won't stay 4unning unless it's on choke
Hi Rebecca, More likely you have a restricted jet in the carburetor. the only real solution is to take the carb apart and clean out all of the passageways.
Mar 24, 2016 | Garden
Mower wont stay running with out being on full choke and manualy movinging the auto advance lever
The fuel jet in the carburetor is gummed up. You'll have to disassemble the carb to get to the jet. spray some carburetor cleaner with the small tube in the nozzle on the jet to clear the gummy build up
Jan 01, 2014 | Garden
The mower will crank over and it will run for a few secounds and stop running why wont it stay running
If it runs for a short time on choke then cuts out it is because there is dirt in the carb jets, you need to remove the carb and clean the internall components.
Jun 08, 2011 | Garden
Mower will only run in choke position
Partially obstructed main jet. Remove carb bowl and clean main jet with small strand of wire. Drain carb bowl and clean out any dirt or rust.
Good luck and be careful.
Aug 04, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Apr 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
224 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
