Question about Whirlpool Refrigerators
We have a 3-month old Whirlpool Gold side-by-side refrigerator. The power is on, but the compressor doesn't seem to be on or cycling. It there a reset switch or another way to get the compressor to run?
  • Whirlpool Master
  • 3,361 Answers
The compressor start relay may be loose.If the compressor fan motor is running, listen for a clicking sound at the compressor electrical terminal. Press on the relay for a better contact. If the compressor fan is not running and the compressor is not hot,you have a defective control thermostat.
Posted on Jul 16, 2009
Whirlpool Conquest Gold White Model# - GS6SHAXLQ03
The relay is the start device,but you need to determine if you need it,try to see if you have power to the compressor,is the compressor running,is the condenser fan motor running,is the coil under the unit clogged with dust,if the fan under the unit doesn't run it will overheat the compressor and it will go off. and if the coil is clogged the same thing goes.
 Usually if the relay is bad the compressor will make a hum and a click noise but will not actually run.about every 5 minutes..
Sep 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unit compressor keep short cycling not feezing or
replace your compressor relay. that's what goes wrong 99% of the time
Jul 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL Relay melted! PLEASE HELP! 1 of 3 Compressor Pins melted! HELP!
Hi, If the pin on the compressor is melted/broke off, the compressor is bad. If the unit is under five years old, check with whilpool and see if it still has a warrenty.
I hope this helps.
Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side
if the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool RSB21 possible power outage.
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person.
Sep 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker and frige
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Feb 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
