Daniel, On your key fob try turning alarm off, if not install battery, then start the car,shut car off and lock doors with remote this will reset alarm.
Reset alarm. Many can be reset by insert and turn key to "on" (this should cancel the noise) wait 15 minutes, turn off. then start normally and see if this fixes issue.
SOURCE: HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
SOURCE: Alarm goes off truck won't start.
you got to press the lock or unlock button on the remote a couple times my truck did the same thing.
SOURCE: alarm problem on my 2001 elantra
This alarm system can only be 'disarmed' using the keyless remote programmed for this specific vehicle. Press the "Unlock" button on the keyless remote -- this resets/disarms the alarm system. If you do not have keyless remote for this vehicle, get one and have it programmed at a Hyundai Service Center. Problem solved.
SOURCE: I have a 1997 VW Jetta GL. I disconnected the
Reconnect starting with positive then negative.
THANKS GUYS, IT WAS VERY HELPFUL.
