Question about Panasonic Televison & Video
Dvd tray will not open - Panasonic Televison & Video
  • 4,472 Answers
Then its broken,
Lee
Posted on Jul 16, 2009
  • Lee A.
    Lee A. Jul 16, 2009
    There is usually a small hole for manually opening the tray. You just have to use a paper clip. Then see if it works. If not most likely it will not work any more. DVD players can be bought for so cheap its not worth repairing.
    Thanks again,
    Lee
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Dvd tray not opening properly
You just simply replace the rubber wheel of an open / close motor. how to fix this: open the cover of the DVD and turn it on DVD, press the open button when the DVD tray out, you can see where the location of the rubber. The rubber usually has no more tense, not strong enough to pull and push the DVD tray.
Jul 26, 2010 | LG Televison & Video
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
DVD tray won't open
Look for a small pin hole in the front of the DVD player. Insert a pin into the hole to open the tray.
Also try right clicking the DVD icon, click 'eject', then insert the pin into the hole.
If the door only opens partially, grab it and pull it open. Then insert a blank DVD into the tray, then see if the tray will open automatically with the disk in the tray. If so, then keep a DVD in the tray at all times.
May 27, 2008 | Televison & Video
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Will not open the DVD tray.
if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
Digital Apex dvd/cd/mp3 player tray won't open
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
Dec 16, 2007 | Televison & Video
Televison & Video Logo
171 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
