Question about Apple Griffin iMic External Sound System
Connecting iMic to G4 iBook
I have just got an iMic and when I plug it into the USB it is as if my computer is not aware it is there. If I try to select the Final Vinyl software I get a message saying I need to purchase an iMic or similar.
I have checked the applications and it isn't shown on the input menu. When I go into systems profile there is nothing shown on the USB socket.
Is it likely to be a problem with the actual iMic unit?
Thanks for any advice
  • 4,889 Answers
Did u try installing the drivers?Here the link..
If it still doesn't work then check if the usb port u have connected it in is functional..u can check this by connecting some other device like scanner, webcam etc., into it..
If it still doesn't work..the the device is probably faulty and u might want to get it replaced..
Posted on Nov 18, 2007
  • eagle338
    eagle338 Nov 18, 2007
    Pls post a comment before rating.
Where can I plug in a microphone on my PC G4, need it to help in learning a new language?
It depends on which G4 you have. If it's a Quicksilver , there is no Mic in, and you'll need a USB audio adaptor to connect a microphone.
Other G4s, it's on the back, right next to sound out.
Griffin iMic
May 03, 2011 | Apple Macintosh Server G4
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
I have a Mac OSX (ibook G4) and i am trying to upload my pictures from my nikon coolpixS560. My laptop doesnt recognize the camera. When I connect it, nothing comes out. Please help
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Nov 03, 2009 | Nikon Coolpix S210 Digital Camera
IBook G4 shows picture of mouse needing batteries
It sounds like your internal trackpad isn't working, and it is currently asking you to hook up a mouse, be it thru Bluetooth or USB - have you tried a USB mouse on it to see what happens?
Oct 30, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Track Pad (Mouse) not funtioning
I think the first thing you should do is make all updates. I know that in some versions of the iBook G4, the trackpad does not work after installing OS X 10.4 (Tiger) before you do the updates. Update your OS X first. secondly, does the button work? Does the trackpad show up in the System Preferences menu? (under keyboard and mouse). It's very unlikely that the trackpad came unhooked unless someone has opened up your computer. If they have, there is a really good chance that they didn't plug it back in, because it's a hassle and easy to forget.
Apr 10, 2009 | Apple iBook Mac Notebook
Will not connect to internet via airport
Start from scratch. Go back to your main computer and create a USB key and try that way.
Wondering, is your MAc setup for wireless?
Another thought, i had the same issue connecting my Mac to my parents wireless. I used the installation disc and that solved that.
Mar 26, 2009 | Apple iBook G4 Mac Notebook
IBook G4 Fan keeps running
next time you experience this, go to utilities.activity will show you what program ir running the "hottest:, and the graph will display what is currently going on. you may have something running your not even aware of...
Jan 01, 2009 | Apple iBook G4 Mac Notebook
HP Laser Jet 4 Plus to iBook G4 serial to usb
serial to usb is not plug and play so i don't believe this configuration will ever work.
parrallel to usb is plug and play 90% of the time.
purchasing and installing a port replicator is a 100% fix as long as the formatter on the printer is working properly. good luck!
Aug 21, 2008 | HP LaserJet 4 plus Printer
Ibook g4 - screen will not appear
Try adjusting the monitor brightness (F2). If you have an extra monitor, try connecting the mini VGA to see if it outputs a signal extenally. The videocard is onboard the, that is one way to process of eliminate.
Also, if you start the machine after the apple chime, hold down the OPTION key. This will prompt you as to which bootable volume to boot from. What this does though, is gives the monitor a signal before the operating system loads.....this usually eliminates the issue being software, but very seldom is no display a software issue.....
Hope this helps.
Oct 22, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Hd does not show up on desktop.
check hdd out on another mac ibook g4 or any mac then if it does same then you know I's the hdd not your mac but if hdd is accepted then you have big conflicts on your mac it will need reinstalling then retest hdd if loads ok then all is fine problem resolved
Feb 12, 2007 | Fantom Titanium Hard Drive
Apple Griffin iMic External Sound System Logo
136 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
