Question about kawasaki Full Suspension Mountain Bike Men
Ksf 400a1 4 wheeler wont start even when pulled gets fuel has spark was riding on wheely when it stopped running hasnt started since
It may be flooding out that is why it wont start try to shut the fuel off and try to see if it will try to start if not try taking the spark plug out and putting a little bit a very little bit of gas in the plug hole and then put the plug back in it and try to start it
Posted on Jul 31, 2009
I have a toro riding mower with a 21 horse power kohler motor that wont start even with ether. I tested the plug and I am getting spark. I am getting fuel to the carburetor as well.
for it to run you need fire fuel and compression. you say you have fire. if you spray starting fluid in the carburetor then you should have fuel. pull the plug out and check the compression. sounds like a valve or valve seat is to blame.
Apr 23, 2016 | Toro Garden
Why won't it start?
Hi Brian:
1) Spark - pull the plug, connect the lead, hold against the head, spin it over. should be a hot blue spark.
2) Fuel - I'd be suspicious of your fuel. Here's a trick I use ALL THE TIME on my Craftsman ride on. For cold starts I remove the air filter and prime the carb with a squirt of fuel. It starts and keeps running. Without the prime it is a PITA.
Hope this helps.
Oct 19, 2015 | Garden
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
Jan 25, 2014 | 2001 Dodge Stratus
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
My weed eater one 875 series wont start
check the three necessities for an engine to run: is it getting gas? is it getting spark? (remove the spark plug but still have it in the spark plug wire and hold the threads of the plug against the head or the cylinder of the engine and pull start it and see if you get spark). is it getting air? (check the carburetor [goes along with getting gas] check the air filter). sounds to me like a fuel problem
Sep 05, 2012 | Briggs & Stratton Garden
Wont start
When you replaced the spark plug, did the plug show a snappy, blue spark when the engine was pulled through smartly? If it did, check for a plugged fuel filter, air cleaner, and muffler. Check the fuel lines for condition. Make sure the carburetor fasteners are tight. Does the primer pull fuel into it? Is the fuel mix fresh? If still nothing, try spraying some starting fluid into the cylinder through the plug hole and pull through. If pops several times, the carburetor may need to be disassembled, cleaned and adjusted. Hope this helps!
Apr 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
1989 Cutlass wont start
the filter on fuel pump might be clogged as well or fuel pump needs replaced
Oct 01, 2009 | 1989 Oldsmobile Cutlass Ciera
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
kawasaki Full Suspension Mountain Bike Men Logo
173 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
