Question about IBM Wheelwriter 30 Typewriter
Right margin I can not set right margin/ Please help. It continues to type over
  • 125 Answers
Hi:
On all IBM Wheelwriters the right margin can always be typed through. The only indication you will get when you reach the right margin is a beep tone. To set the right margin, space to the desired point and depress the right margin key once.
Andrew
Posted on Jul 17, 2009
3 Suggested Answers
  • 120 Answers
SOURCE: SETTTING MARGINS
Use the margin release or mr key to be able to get past the current margins. Position the carrier to where you want the margin then press left or right margin set. Lawrence
Posted on Jul 28, 2008
SOURCE: Right Margin
where is the Alt key????
Posted on Nov 03, 2008
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Typing Arabic way
if it is printing the correct words it is most likely set for right margin flush turn the right margin flush off
Apr 07, 2014 | Nakajima AE-800 Typewriter
Types only one letter
Press margin release before you hit return then continue typing. You may have set the right margin.
Nov 18, 2013 | Royal Satellite 80 Typewriter
Cant typer further than 10 characters
The trouble is probably the silver shaft that the carrier slides on is gummed up. Try a little WD40 on the shaft, if that dosen't work the carrier motor in the L. rear corner may need lubricated, WD40 will do that too.
DickyO
Sep 24, 2009 | Office Equipment & Supplies
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 02, 2009 | Office Equipment & Supplies
I have a swintec 2600 i cannot get it to clear out the tabs and i need to type beyound were the tab is
You must mean the margins. To move the right margin further to the right. Move the carriage to the right margin then depress the mar release key then space over further to the right to a new position and depress the right margin key. You should here a beep. If you just want to type further to the right of the margin, when it stops typing, simply depress the mar release key and continue typing.
Jul 21, 2009 | Office Equipment & Supplies
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
My electric typewriter the AX-430. I have lost the Manuel and cannot take the format off, it only types to the center of the page and goes no farther. any help?
Sounds like you need to reset your right margin. Spacebar to the right as far as the carrier will go. Hit the Margin Release key and then continue to spacebar to the right where you want your right margin set. Press "Code" and "Right Margin Set" (or similar name, not sure of exact key name here) to set your new margin. Should work ok now.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 15, 2009 | Brother Office Equipment & Supplies
Right Margin
Nov 03, 2008 | Brother ML-100 Typewriter
SETTTING MARGINS
Jul 27, 2008 | Brother SX-4000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
117 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
