Question about Jenn-Air Ovens
Hello, My Jenn Air oven overheats. When I set
Hello, My Jenn Air oven overheats. When I set the temp for 350 or above, it continues to heat well above 500. I have had the touch panel and clock replaced. I am checking resistance on the oven probe.
  • Jenn-Air Master
  • 3,361 Answers
The temp probe resistance should read between 1050 and 1150 ohms. If not. Replace it.It causes the overheating situation you describe.
Posted on Jul 16, 2009
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Whenever oven in on 350 bake, temp keeps going up. Finally had to turn breaker off. It showed f2 on error code
Hi... an F2 code means you have a bad "temp sensor" They are really easy to instill
Mar 27, 2011 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
When baking a cake or bars the oven is set to the recommended temperature and baked for the recommended time and the middle doesn't bake all thru.............gooey.
Put a thermomiter in the oven and set oven to 350. Once oven says it has reached temp. Give it about 15 min and check the thermomiter you placed in the oven to see if it maches.
This is where I would start.
Jan 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Apr 29, 2009 | Jenn-Air JJW9830D Electric Double Oven
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
577 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
