Question about Acer Aspire L100 PC Desktop
I shut computer after windows updates and now it won't power up
I shut down computer after windows updates and now it won't power up .powerb supply is ok
  • Amruth Louis May 11, 2010
    Upto which point does it boot up?
  • 374 Answers
1.Try booting into safe mode (F8 on startup) and then uninstall the update or you can run system restore. 2.try going to the advanced boot options and choose "Last known good configuration" 3.The last option is 'to do a repair install' if you have a Windows XP CD you can just do a repair of the OS.
Posted on Jul 16, 2009
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
Not detecting in my pc
hmmm so you have this on USB port. you might want to try this first:
A. shut down computer and ext drive power
B. Turn on computer and let boot up, w/o hard drive power on
C. Make sure ext drive is plugged into usb port
D. Then turn power on ext drive
Windows should 'see ' the drive and add it your my computer
let me know if that helps at all
May 17, 2012 | Transcend StoreJet 320 GB USB 20 Hard...
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
I jus left my computer optiplex gx260 on and when
Your automatic update from microsoft probably updated your machine and shut it off, by default it is set to update if their is one, every tuesday at 2:00 or 3:00 am and will either restart or shut down your machine.
if thats not it then your computer may have gone into hibernation or standby.
May 25, 2010 | Dell POWER SUPPLY Power Supply
Toshiba satellite A70-KL1 notebook shuts down
Scan the Computer using any latest updated anti virus program for any potential threat.
If the computer is not infected by any virus or trojan then you may also try performing System restore to the time when the Computer worked normally.
If the Computer keeps shutting down randomly after turning ON then the Power Supply Unit in the Notebook requires service.
Sep 15, 2009 | Toshiba Satellite A70 Notebook
Computer shuts down on its own hard drive just completly shuts off have to hit power button to restart it. I am thinking that it could be power supply going bad because at times it does have a slight...
Hello mr_nasty_72,
Your problem could be several things. Your hard drive is either over 90 percent full and the windows swap file is dumping the computer to shut down. the hard drive has a bad spot i it and when the system writes to it, then computer shuts down. Your memory has a bad spot in it and when the file useage of the memory gets high enough and finds the badspot, the computer shuts down due to the error. I would run a memory test program on the memory to ake sure it is not a memory error. Also rin a utility like spinrite on the hard drive and see if it can repair any bad sectors it finde and recovers any lost information on the drive. If your computer is new enough you cn go into the bios setup and look at the system utility for the power and fan system on the motherboard. This will tell you if the power supply is putting out the correct power voltage for the system. Regards, rcampsr
Feb 21, 2009 | Acer Aspire™ T180 PC Desktop
After i load ssp2 my computer does not open window program
What is 2.2 frame?
Do you mean .Net framwork 2.2 update from microsoft?
Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
.Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
Continue to update you're windows.
Please let me know if this has helped.
Good Luck!
Mike
May 08, 2008 | E-Machines eMachines Desktop PC
Acer Aspire L100 PC Desktop Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
