Question about John Deere A,b,g Tractor Carburetor Float Dltx10
MG 1990 john deere 12 hp riding mower no spark has new coil and spark plug also checked fuses are ok
  • Anonymous Mar 15, 2014
    Kohler 12.5 HP has no spark coming from coil
    President:
  • 1,486 Answers
Change the ignition module.
Posted on Jul 16, 2009
Can someone guide me through troubleshooting this ie which safety switches to check etc.
try a new spark plug. they breakdown over time. if still no spark unplug the wire under the coil. if it does not have spark now replace the coil. if it does have spark you have a bad switch somewhere.
Oct 30, 2016 | John Deere Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John deere lawn tractor 175. engine turns but No spark from spark plug
some of the safety switches will shut the spark off unplug the harness from the engine then crank it over if you have spark there is a problem with a saftey switch if you have no spark the problem is the coil
Apr 13, 2012 | John Deere Garden
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
I have a John Deere riding mower Model RX75 which will not start, I replaced the spark plug and it ran just fine for one day except that it Back-fired when I shut it off it never did this in all the years...
Weak spark can be caused by a bad ignition coil. The ignition coil is located under the engine fan/shroud, next to the flywheel. Check to make sure the coil lead and plug cap are not grounding against the engine robbing your spark as well.
Aug 03, 2011 | John Deere Garden
My jd x324 will not start. it has fuel, we had a faint spark at first with new plugs we now have none.
Check the gap on your plugs first, than you must lean towards the coil it may be faulty or bad. Then you need to replace coil assy. You should see very strong spark with new plugs.
Nov 18, 2010 | John Deere 22HP Hydrostatic 42" Riding...
Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Jul 16, 2010 | John Deere Garden
John Deere A,b,g Tractor Carburetor Float Dltx10 Logo
274 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
