Question about Dryers
It does not work. The light is on inside and the timer is ticking but it does not start.
    President:
  • 1,776 Answers
I would take a look at the thermal fuse and see if it is blown. You can test it for continuity with a ohm meter. If bad, it will have to be replaced, it can't be repaired. Hope this helps.
Posted on Jul 16, 2009
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
Will fill with water but doesn't start cycle
One possibility is that the timer motor has failed.
That would mean the timer should not be sounding like there is a clock (ticking) inside, and the knob should not advance as it ticks.
You can listen for the ticking by putting your ear to the control panel on top.
The reason it fills is that that is the first step, and it would do that, even if the times doesn't work sometimes.
Be blessed.
Apr 20, 2013 | Washing Machines
I just installed a GE Smart Digital Timer. After I programmed the timer and went to manually turn on the light the light started to click on and off and the timer ticked?
Timer wiring instructions shown on following page:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
Dec 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Timer doesnt tick but works if moved manually
The timer has come to the end of it's serviceable life. Being mechanical, they wear out and are not designed to be econonomically fixed.
It needs replacing.
Regards
Jan 14, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
OLD wall timer Model E1020 ticks really loud
You probably can't get the existing mechanical timer to operate any quietier, since it's old and likely starting to wear out. You can either swap the timer out for a new automatic digital timer, or install a standard single pole switch in its' place.
I believe the code you refer to regarding the fan having to be wired onto a timer switch was a local requirement from many years ago.
Some local jurisdictions have impossed more stringent requirements, but frankly, having an exhaust fan is normally a good idea. If the fan is vented into the attic space, it can cause some serious problems in cold weather with condesation of the warm, moist exhaust air.
Building Code requires that bath fans be piped/vented to the outside of the house and not into the attic space.
There are newer preset timer switches that will turn on the exhaust fan for a fixed amount of time, based on which button you push. These are great as they will run the fan long enough to remove condensation from showers, etc.
If you're going to replace the timer, disconnect or turn off the breaker or power to the switch. Then simply install a new timer or switch by connecting the black supply wire to the bottom of the single pole switch, or to one of the black leads of the timer. Then connect the black wire going to the fan to the top screw on the single pole switch, or the other lead on the new timer. The white (neutral) wires should already be connected with a wire nut inside the box. Connect the ground wire to the ground wire in the box and if the switch box is metal, attach the ground wire to the box with a green grounding screw too.
You can now operate the fan with either a manual on/off switch or the new digital timer, whichever you chose to install.
Sep 04, 2009 | Heavy Duty Intermatic Wall Switch Timer...
Dryers Logo
27 people viewed this question
Top Dryers Experts
