Question about Garden
Weedeater will start-up and run for only 30-45 seconds! Can NOT get it to stay running!
  • 9 Answers
SOURCE: My weedeater won't run in 'run'.
Sounds like the carburetor needs adjusting. The owners manual should show you how to adjust the carburetor. If not, I would take this to the place of purchase and ask them to repair or replace it.
It should be under warranty for at least 2 years. I have had the same problem and when the carb would not adjust to run properly. I took it back and got a new one . This was at lowes and they were really great about it. If you decide to return it, clean it up real good.
In california we have different regs on outdoor power equipment and can adjust the idle only. The carbs are different for the rest of the US.
They can usually be adjusted, If not take it back. You deserve to get what you pay for without problems like this.
Posted on Jun 14, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
  • 64 Answers
SOURCE: Weedeater does not stay running
its possible. i could see it being that the carb diphrams are not pumping enough fuel to the carb, the filter screen in the carburetor has a varnish glaze on it or plugged and could be the jets are partiall plugged.
Posted on Apr 09, 2010
SOURCE: Ryobi weedeater 4 stroke starts but only runs for
We have a Ryobi gas weed eater. We can get it started but it doesn't stay on. I took it in to get it fixed and he said it was the primer switch, which he replaced, but we are still having the same problem.
Can you help us or refer us to a Ryobi repair store? We live in Phoenix, Arizona but can go to any repair store in Glendale, Tempe, Phoenix, Mesa, Scottsdale, wherever in Arizona. Thank you. Sally
Posted on Jun 26, 2010
rycgl
  • 1545 Answers
SOURCE: Husqvarna 28cc weedeater primed x3...choked
This sounds like a fuel starvation problem. These units use temperamental little diaphragm carburetors which can develop assorted ills and problems. Sometimes, the problems stems from debris in the carb, fuel tank, fuel filter, or inside the carb where there is another very fine filter. You have stated that it runs 30 seconds, but I don't know if it is IDLING for that period or running at speed for that period. At any rate, check the in-tank fuel filter, ALL fuel lines, and if you can remove the fuel pump cover on the carb (it does NOT have a vent-hole), and check inside where the little round fine wire mesh screen is. Check it for debris.
If all the above are OK, then the carb may just require a small adjustment. The problem here being the type of screws used to adjust the Low and High speed mixtures on the carb. Some have splined heads, some have Pac-Man shaped heads, some have D shaped heads, and some have Double D shaped heads. Older ones have conventional slotted screw heads. On the non-conventional ones, you can use automotive type wire terminal spade connectors. Before you put them on though, you need to note the exact position of the mixture screw you are going to adjust. After that, tap the connector onto the head of the screw. If you use a female spade connector (22 gauge or so), then the end of a small flat blade screwdriver will fit the spade and you can turn the screw. I will refer you to an excellent Zama (probably your carb) carburetor adjusting tutorial now.
http://www.zamacarb.com/tipspage.html
Try these things and feel free to post back. We will continue to try to help with your issue.
Posted on Aug 06, 2011
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Weedeater blower will not stay running
how long will it run? 30 seconds 10 min.
pour ot the gas & look inside the fuel tank is it dirty?
is the filter still hooked up to the supply line. Mine had fallen off [worn out] I replaced with new fuel lines and still had a 20 sec run. It was flooding let me know
Sep 02, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Weedeater 25cc Blower
Its obviously fuel starvation, start withe the easy stuff first, use a peice of bent wire to hook the fuel line out through the open filler hole, the filter on the end then needs to be pulled off and replaced, try this first before we get into the carb.
Jun 25, 2013 | Garden
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
Weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Jun 18, 2009 | Garden
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
