Question about Praktica DCZ5.0 Digital Camera
Hi My PRAKTICA DCZ 520 camera is saying CARD LOCKED when i switch it on, i cannot take photos, can anyone help me to unlock it please. Isabella
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
What cable do I need to download pictures from my DCZ 7.4 camera to my PC?
The manufacturer's website does not indicate the type of cable needed.
http://www.praktica.de/index.php?id=21&L=1&tx_prdigital_pi1[showUid]=347&cHash=2ef074a2c3
However, it uses a common type of memory card SD.  You can take out the card from the camera, insert it into an SD card reader, and the reader's USB jack into the back of the computer. Your photos can be downloaded at Start/My Computer/ and click on the SD card volume (E: or D: etc ) and open any folders inside to see your photos, copy and paste them to your hard drive.
Alternately use picasa software or the irfaniew viewer from www.irfanview.com to import, view and edit these photos from the SD card.
Dec 09, 2010 | Praktica DCZ2.2S Digital Camera
Card locked! problem
If your camera uses and SD card. Take a look at the card. There will be a little switch on the side of the card. Move the switch to the unlocked postion, reinsert it in the camera and turn the camera on. It should fix your problem. Thanks for coming to FixYa.
Rob
Mar 17, 2009 | Praktica DCZ1.3S Digital Camera
Praktica DCZ 3.2 D transfer pics to card
just phoned the praktica company and you cant download from camera to memory card you need a usb lead which they supply at £10.00 cheque or postal order
Dec 06, 2008 | Praktica DCZ3.2S Digital Camera
Transferring photos from camera to PC
I clicked through and found a mode on camera that I hadnt seen before
and it worked after that thanks.
Jul 12, 2008 | Praktica SlimPix Digital Camera
Praktica dcz unable to delete photos and take picture
You probably have a memory card in your camera.
Remove it and check for a nearly microscopic slide switch on one edge.
This is a 'protect tab' and will not allow you access to memory unless it is properly set.
May 20, 2008 | Praktica DCZ3.2S Digital Camera
Cameras Logo
155 people viewed this question
Top Praktica Cameras Experts
Jose Ma DM.
Jose Ma DM.
Are you a Praktica Camera Expert? Answer questions, earn points and help others
