Question about Stanton STR8-100 Turntable
Powere input I fried my stanton st-150 but plugging it into 220v instead of 110v. Is it fused. I want to open it up and check but am not sure I will ruin it?
  • 515 Answers
Some ST-150's have fuses, some do not. It would be on the rear of the unit, next to the power cable. If it is not there, then it might be under the turntable platter, on the main board. Not sure if you have a US or non-US model. So check both places. If you cannot find the fuse, then you don't have one. It's not that hard to locate. If this is the case, then your power transformer probably fried and will need to be replaced. This part runs about US$40
Posted on Nov 22, 2007
No power to my microwave
first check the mains power chord for continuity and open circuit.
if this is ok then check the input voltage .(either 110V/220V)
Check these and tell me .
Mar 27, 2014 | Whirlpool MT4078SKB / MT4078SKQ 700 Watts...
Rewiring tone arm stanton st.150
Nice , i just received my tonearm wire for a technics. mk5
First question , Which tonearm are you try to put in and why, since if you want a better sound , sell the unit instead of useless replacements and do you use the phono or line out...
Feb 15, 2014 | Stanton Audio Players & Recorders
Blender was connected to 220V instead of 110V and ON button was pressed, I heard a sound and perceived burning smell, after opening the bottom i noticed a burnt component(Mica capacitor) with a diode...
More than likely you fried the boards and even if to change them out ,you still run the risk of electrical shock. My advice is to send it back to the company for repair or get a new one. Plugging a 110 unit into a 220 line has happened to me too! I still feel pretty stupid I did it, but stuff like this happens and it is good that you were not injured.
Dec 05, 2013 | Blenders
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Jul 05, 2010 | Televison & Video
Over-voltage connection - 220v - instead of 110v
That thing is fried.If you can do your own electronic repair,there are a few components where the plug comes in that would be cheap to replace.Without a solder gun and voltage meter though I would replace.
Jul 20, 2010 | Timex Auto-set Clock Radio
My system 110v mode i am connect 220v now not working my be what is the problem
your power supply is shorted.. make sure to connect your new power supply to the actual voltage .. 220V is for 220V input PSU.... if you connect your 110V PSU to 220V outlet... it will fry your power supply..
May 24, 2010 | Gigabyte GA-945GZM-S2 Motherboard
My 110v humidifier plug into 220v
it would not be worth fixing. all electronics would be fried
Oct 05, 2009 | Humidifiers
CHI Flat Iron GF-1001
I have bought thermal fuses from DigiKey. They have various temperature ratings. If you have a multimeter or ohmmeter you can check to see if the fuse still has continuity. If the iron sometimes works, it's not the fuse. Cords are the most common problem, but if it was plugged into a 220V I'm not sure what might have gotten fried. There is a small IC in there too, for temp control or something: if it's fried you are SOL. Save it for parts though...
Nov 13, 2008 | Oster 76076-010 Hair Trimmer
Stanton STR8-100 Turntable Logo
216 people viewed this question
Top Stanton Audio Players & Recorders Experts
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
