Question about Acme 5001 Supreme Juicerator Juice Extractor
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks), apple (1/2), and a small cucumber that I deseeded. I put everything in but the second half of cucumber caused the machine to jump around and spin on the countertop, popping the lid off. It makes me not want to use the juicer. I use a filter each time. Could it be that there is too much pulp? The above ingredients aren't that many and it seems like it shouldn't do this.
    Champion:
  • 356 Answers
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Posted on Jul 18, 2009
Russell Hobbs Juice Extractor Won't Start
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
May 12, 2014 | Juicelady JL500 Juice Extractor
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and...
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
Apr 22, 2011 | Acme 6001 Juice Extractor
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
My juicer spins off of its axis i think, wobbles all over, spinning itself in circles spewing juice everywhere
Omega and Acme juicers will vibrate because pulp
is not ejected during juicing. Only suggestion I can
offer is avoid soft produce and feed as slowly and
as evenly as possible. Been using an Acme for 21
years and did notice a duller worn blade does produce
less vibration.
May 23, 2010 | Omega 1000 Juice Extractor
I have a Krups Vitamight model 294 juice extractor. My son used it and now I can't get the pulp container off. I have never used it and the the manual is gone.
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
Nov 20, 2009 | Krups Juice Extractor
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
Wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Aug 05, 2007 | Omega 8005 Juicer
Pomegranate
Well ya can juice 'em but it's a bit labour intensive .. lol 'cause ya gotta skin 'em, and get ALL the "Seeds" out, they taste bad... then put the pulp in.. and juice away... yield is low also .. but tastes real nice in the end.. I usually do it in a plastic bag,and tip the pulp into the juicer. Ya can make great "leathers" too..
Aug 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Acme 5001 Supreme Juicerator Juice Extractor Logo
344 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
