Question about Microsoft Xbox 360 Console
X-box AV cables
The x-box turns on but there is no picture or sound. The AV cables are all plugged in. What can i do about it?
  • Alan
    Alan Jul 16, 2009
    its not the red ring and i just needed to know if i could do something about it.
    Problem Solver:
  • 7 Answers
Have you tried moving the angles where the red meets the wire thats what i did it worked for me
Posted on Jul 18, 2009
  • 3 Answers
You need the red ring fix there is nothing you can do but send it for someone to fix.....
Posted on Jul 16, 2009
The sreen is out, sound works fine, turned it on nd screen isn't displaying
Make sure you have the AV cables (the colored ones) plugged in correctly to your cable box, or other receiver. An improperly plugged in AV cable can completely disable certain functions (such as sound, video, etc.)
May 04, 2011 | Televison & Video
When you turn the tv on, it plays for about a minute and then the picture goes black, but the sound is fine. Then you turn it off and back on and the same thing happens after about a minute.
Is it connected with HDMI? or Component, or AV cables? If HDMI, is it
connected to an AV receiver? if so, disconnect from the AV receiver and connect straight to cable box. You may also try connecting component cables if you have them
HDMI is still quirky depending on your receiver, cable box etc. Lots of veriables.
Check that first, if you still have an issue, post a comment with all makes
and models of products connected and I can help further.
Sep 27, 2010 | RCA L32HD32D 32 in. LCD HDTV
My ps3 will turn on but wont show a picture on the tv or give sound
Reset the video settings by turning on the ps with only the power cable plugged in, when turning on continue to hold the power button until you hear a second set of beeps then turn off the console.
Boot up the ps and plug in your av/hdmi cable and you should have picture and sound.
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Hooking up to the television s-cable and two audio jacks. I have a picture of the dvd but the sound comes from the television program in the background
The S Video cable and the two audio cables should be plugged into the same av input on your television. It sounds like the sound cables for your cable box or satellite tv box are plugged into the television where the two audio cables for the DVD player should be.
May 05, 2010 | GE 1106P DVD Player
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Hi my tv turns on but just shows a blue screen and the sensor light flashes red there is no picture or sound ive tried switching it of from the mains plug sky tv in and another dvd player but no good any...
try the av buttons on your remote, see if it switches to ur external box.
if that doesnt work, try a s-video (and rca audio cables) to scart adaptor (with those mensioned cables)
from the box, if that works, could be something to do with the scart?
or could be a av issue,
Jan 02, 2009 | Televison & Video
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Microsoft Xbox 360 Console Logo
67 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
