Water does not stop at the proper level. Keeps running and will overflow. Once it gets to the spin cycle is does not continue to run. If I let it fill, cut off the water at the valve and then refill it for the rinse cycle and cut it off again, it's ok. I am not sure how long it has been going on. Wife told me that it was running slow, so I cleaned the filter, and then noticed this problem on the first load. I appreciate any ideas. It seems I may have a bad float valve of some sort. Thanks, Brent
    President:
  • 1,776 Answers
Sounds like it could be the water level switch. An obstruction or defect in the water level switch will make it not tell the water to turn off, overfilling the machine. The switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear plastic tube between the switch and the bottom of the washers outer tub. As the water level comes up, the pressure on the air in the tube increases. When it reaches high enough, it trips the switch, shuts off the water, and signals the timer to begin the wash cycle. Clear away any obstruction in the tube or replace the switch. Hope this helps.
Posted on Jul 16, 2009
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
The water level selector of my whirlpool white magic-splash washing machine is causing problem..it does not stop the water at the desired level..the water keeps on flowing into the tub and then overflows...
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 09, 2011 | Whirlpool Washing Machines
Water overflowing and never shuts off
Jammed solonoid valve open position.....
Nov 02, 2009 | Frigidaire FWS1233F
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Jackson 200B Series Commercial Dishwasher Fills With Water and Drains
Could be one of two things. 1 - The cheap fix might be that the probes in the wash tank are dirty. There might be a "coating" on the probes that prevent the sensors from knowing that the water has reached the proper levels. 2- Replace part "Liquid Level Control" - $$
Apr 03, 2008 | Dishwashers
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
