Question about KitchenAid KTT570 4-Slice Toaster
Handle won't stay down - KitchenAid KTT570 4-Slice Toaster
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
It sounds like the spring or coil is damaged. try to open the product and see what happens with the spring. it's an easy fix to replace a spring. but you will have to open it first
Posted on Sep 08, 2009
  • Eric Koonce
    Eric Koonce May 23, 2011
    It's a good suggestion but where can I purchase a replacement spring?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 10 Answers
Try pacific8's answer to this problem with another KitchenAid toaster, especially the comment on that answer by pacifics pam, all found here: http://www.fixya.com/support/t9655297-toast_will_not_stay_down_in_toaster_when
Posted on Nov 24, 2014
This toaster stays down with an electro-magnet which for some reason has decided to stop holding down the weight of the springs within the kitchenaid toaster. This really is a shame considering I bought this due to my experiences with the professional grade kitchenaid items.. No idea how to fix I am tinkering lol
Posted on Dec 19, 2011
  • MindAltering Dec 19, 2011
    Actually just fixed it, remove the screws on the bottom of the toaster on te side where the handle is after removing the case remove the rod holding the handle mechanics, I then cut a quarter of the spring, placed it all back together. Wah-lah working toaster. Still turns itself off and actually has enough "spring" left in the release to lift your toast. Annoying that I had to do this. But at least my 3 dollar purchase at the goodwill was well worth it.
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
Hatchback won't lock on saab 9-3
I had the very same problem with my 2002 Saab 9-3 after I manually moved the trunk latch to the locked position "out of curiosity..." Then I noticed there is a handle you can pull to release latch opening it up! Very simple remedy... It is a glow in the dark green plastic handle hanging down when the trunk/hatch is open dead center, just in slightly behind latch... Gently pull handle until you hear and see the latch click into the open position...Let me know how You make out. BTW: Toyota Camry has the same set up,same color as well...lol Good Luck!
Oct 16, 2012 | 2002 Saab 9-3 SE
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Tailgate won't stay closed
try spraying the latch and mechanism with wd 40, both sides and handle. the bezel where the handle is at just pops out spray the pivot points and the latch cylinders on the sides of gate
Sep 04, 2012 | 1996 Chevrolet Silverado 2500
Ice bin metal handle won't stay up?
It may have just popped out of place and needs to be re-adjusted, but if that''s not the case then the modular head has broken on the ice maker and it should be replaced
Jun 05, 2012 | Refrigerators
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
I have a crank style patio umbrella that won't stay up when we try to crank it up. How do I fix this? You crank it up and it just rolls back down when you let go of the crank.
We had the same problem. We simply used a bungee type cord to hold the crank handle in place once the umbrella had been opened.
Jun 26, 2011 | Garden
Where do I find the front hood release on the car?
Bottom left next to driver's door is the pull handle.
Reach under the hood (you may have to pry a bit to get your fingers in there, particularly if the hydraulic gas lifts are dead so the hood stays down), slightly down and right from center. There's a flat lever you'll push right to release the catch.
Have about a 4' stick handy to prop it up if the lifts are dead, and make sure it's someplace which won't slip, if you do that.
Lube the mechanism with light oil such as 3-in-1 while you're there, and replace the lifts if they won't hold the hood up, not a big deal to do or costly...
Apr 16, 2011 | 2000 Mercury Grand Marquis
2000 Ford Crown Victoria
when you hold the accelerator does the vehicle stay running? if so the problem is in ithe IAC idle air control motor, take a small screw driver and using the handle tap the iac motor and usualy the motor will kick in and the vehicle will run fine then if the problem is rectified replace the IAC
Nov 24, 2008 | 2000 Ford Crown Victoria
KitchenAid KTT570 4-Slice Toaster Logo
711 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
