My acer aspire 5315 is stuck on dis screen, n I don't have a reco
Broadcom UNDI PXE-2.1 v10.0.9
Copyright (C) 2000-2006 Broadcom Corporation
Copyright (C) 1997-2000 Intel Corportation
All rights reserved,
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting ]roadcom -- insert boot disk and press any key
  • 555 Answers
Hello my friend, regarding on your problem it is clearly that your system cannot boot from its kernel part of the Operating system. It is experiencing a software corruption or corrupted files of your operating system. The only solution you can get is to re install your operating system to replace and repair any damage files in your operating system.
Thanks
Posted on Jul 29, 2009
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
I have a Acer Aspire 7741Z-5731 and when I turn it on this is what it says: Broadcom UNDI PXE-2.1 v12.2.2 Copyright (C) 2000-2009 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights...
When you start your PC it goes through a power on self test (POST) procedure to make sure all the hardware is working and there are no compatibility issues. It looks like some of your hardware has failed. This could be the hard drive that has failed, or possibly the RAM. One thing to try is remove the RAM, clean out the bay by blowing or using compressed air and reseat the RAM. Try it in a different bay or if you have two sticks, try replacing one at a time and try to boot the machine each time. Another thing you can try is booting to BIOS (your machine should tell you which button to use to enter setup when it starts, possibly F2) and check the info tab to see if you can see all the drives listed. You should probably see at least two, the hard drive and the cd drive. If you don't see the hard drive then it's probably failed.
It may be best to take the machine to your local PC repairer to have it checked.
Mar 29, 2012 | Acer Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I was using my laptop last night when it just shut down on me, then when i went to turn it back on it goes to the acer "start up" like page before skipping to a black screen and displaying the following...
If you have a BOOT CD then try to boot and go to windows.
Or you can use windows setup CD but go for repair only.
For the future it is a good idea to INSTALL WINDOWS in a USB mini drive and boot the computer from USB. You have to go to BIOS and set USB default drive.
It is a good idea to clone your HD in a CD.
Sep 04, 2010 | Acer Aspire 3690-2196 Notebook
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
My aspire 5315 laptop is stuck on this sceen, broadcom undi pxe 2.1 v10.0.9 copyright (c) 2000-2006 broadcom coporation copyright (c) 1997-2000 intel corporation all right reserved. pxe-e61: media test...
Hello higgstwiligh,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 01, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 is stuck on dis screen, n I don't have a recovery disk to reformat it, wat can I do? Broadcom UNDI PXE-2.1 v10.0.9 Copyright (C) 2000-2006 Broadcom Corporation Copyright (C) 1997-2000...
your operating system is broken. or infected by virus, file corrupted.. neet to repair if could.. but if not re install the os...
save first all the inportand documents in external hdd or in drive d before to start re install the os
Jun 14, 2009 | Computers & Internet
My acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Jun 07, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
