Question about Magellan Maestro 5310 Car GPS Receiver
My magellan maestro GPS unit won't hold a charge with the house charger. I charged it for over 6 hours last week and the battery was fully charged. Today I got it out and it's dead again. This unit is only 6 weeks old. Anyone else having this problem? Any solutions? Thanks
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Dec 13, 2010
2 Suggested Answers
  • 1111 Answers
SOURCE: Magellan Maestro 4040 gps
the folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
bill
Posted on Jun 21, 2010
bill
Apr 11, 2010 | Magellan Maestro 4040 GPS Receiver
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Replacing the battery in a magellan maestro 4370
thats a fairly new unit and i doubt if the battery is shot already. it could be, but verify that is shot.
1st verify that its charging. hook up the home or car charger, then go into the main menu, then options, then power options and see if the battery indicator is moving left to right..if it is, its charging. if its not moving and shows a low battery, then its not charging.
if the meter is fully green and shouts off when unplugged form power, i would disconnect the battery then hook it back up and check the charging again
let me know if you still need to replace the battery and ill find you one and tell you how to replace it.
Bill
Nov 18, 2009 | Magellan Maestro Elite 4370 GPS Receiver
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan Maestro 4000 GPS
Magellan maestro 4040
plug the unit in and press the silver button by the left side and make sure the unit is fully charged if not,plug in the home charger and iti will be fully charged 3 to 4 hrs,also if the battery is fully charged the unit should turn on after you press the silver button on the left side and hold for a few secs. without the car or home charger.also chk your cd manual for further info.let me know what happens.ok.
Feb 27, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Jan 31, 2008 | Magellan Maestro 4040 GPS Receiver
Will not come on.
GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 5310 Car GPS Receiver Logo
168 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
