Question about Apple iPod touch
Wifi won't work!
Hey, i have a similar problem except mine shows that my wifi is connected in settings but the internet still won't work!
  • moneyman6785 Jul 16, 2009
    My friend has the same problem at my house is it possible it's the wireless router? the laptop works fine but the iPod doesn't.
  • 3 Answers
Try rebooting your ipod. This is a glitch I have often encountered with Apple's 2.2.1 firmware (and earlier). If you dont have the 3.0 firmware try installing it and see if it solves your problem
Posted on Jul 16, 2009
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
May 26, 2017 | Fujitsu Computers & Internet
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
I don't know what part of the icon bar to use to connect to the internet through my router, can you tell me?
are you using pc of phone
on pc there will be a tool bar (line of icons) at the bottom of the screen one will be E in a circle that is the explorer browser that will connect to the internet.
Feb 11, 2015 | Computers & Internet
Wifi is connected but internet is not working :(...help me
Hey,try checking with different laptop or phone connecting with your wifi.You will figure it out whether it is a wifi problem or your phone.If it is the phone problem try to reset so that it may solve the problem.Because i had undergone the same and i tried to reset as it is a brand new phone and i dnt have much applications , pictures and other stuffs on my phone and it worked fine.I dont know how it solved the issue, but i guessed it would solve and i performed the reset.You can also try with this.Good luck:)
Mar 09, 2013 | ZTE Score
How to fix internet sharing
Not sure if you try to set up a WIFI Access Point or are you trying to share internet access through a PC? I will try to answer anyway... You need to connect the RJ45 (that square-ish) to your wireless router on the WAN port.
Feb 13, 2013 | Computers & Internet
Connected wifi but no internet in my htc touch p3450?
Maybe your problem is that everything is set to "my work connection".
most programs default on "the internet".
maybe you could try and remove all those connections except "the internet", and configure that one.
you could always just format and re-install windows mobile, and add touch flo later.
but i'm not sure if that is available just like that
Jul 26, 2012 | HTC Touch P3450 Smartphone
I have a samsung champ duos gt-e2652w,i can't
Could be the wifi signal, or your phones data settings
May 15, 2012 | Samsung Cell Phones
My touch shows that I have a wifi connection, but i cant use it.
All you have to do to the ipod is go to settings, wifi and make sure its turned on in the same place you should see a list of wifi networks you can connect to just tap the one you want and the ipod will do its thing your done, but if you done all that and you ipod doesnt go online says connected but wont access the net, my guess is the wifi router you mite have some prob with that, make sure the internet ethernet cable is pluged into the modem plug not the numbered slots after this you should be good to go unless your wifi modem is new if so some req you to plug it to your computer via ethernet cable to program it first! Hope this helps
Jul 13, 2009 | Apple iPod touch
Itouch shows connected but when used says theres no internet cone
go to settings... and view the connection... select the little arrow to the right of the name of the connection.. and select "forget this connection" turn the wifi off... then back on.. and connect back on the network and it should work. it fixed my mine. i had the same issue. goodluck
someone posted this a long time ago.....I just copied it ...it worked for me.
have a nice day
Jan 17, 2009 | Apple iPod touch
P1 wifi configuration
Hello laserxp,
for this time i want to tell you that i am not very familiar with the P1 wifi, however as my experience on the some wifi connection i only read the usermanual manual of the unit connecting to the internet.
please show me a picture and the model of the wifi so that i can figure out your problems.
melnavz
PS: pls donot rate me if the solution donot solve the issue.
Jun 27, 2008 | Sony Ericsson P1i
Apple iPod touch Logo
153 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
