Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hi problema hi i am from greece i have the 320gb but  It does not recognize the my book while it turns on light? it has fallen to me  unfortunately.  what can i do? thanks dont know good english help me!!!!!!!!! christina
  • 1 more comment
  • 3a8oula Nov 18, 2007
    do not link I mean… it fell to me under
  • 3a8oula Nov 19, 2007
    omg i dont understand english .... do u mean that it broken for a life ????
  • 1,006 Answers
Hello Christina:
The EXTERNAL is damanged
Hdd is FINE...
Just change the external or buy new
Try this metod:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Nov 18, 2007
  • arben pllana
    arben pllana Nov 19, 2007
    I told you that just EXTERNAL is damanged NOT HDD witch are ini in external.OK UNDERSTOOD NOW?
I look for manual book of a Canon 3000 in Greece .
Hi lakislakis80,
im afraid i cannot find the Greece manual for you but here is an english version in case
Visit these Links to download your Manual :
I hope this helps, good luck!
Mar 16, 2011 | Cameras
When I am charging the mac book the orange light is turning to green then orange again.. why is it like that? how can I repair it?
This may indicate that your battery is going bad and not holding a charge. Try inserting a different battery and see if the light stays green.
Jul 12, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
My computer stopped recognizing My Book 320Gb. The blue light is out. When I connect it to a different USB port, the blue light blinks three times and repeats that pattern two more times. Then the light...
Do you hear the motor on the drive?It could be a firmware issue.your best bet is to call western digital if you are still under warranty,there website should have software which will enable you to test the drive or download any available firmware.
good luck
Jun 29, 2009 | Western Digital My Book Essential 500GB...
My Book green light continuously blinks and is not recognized by
mine does the same thing ..they must be unplugged from your power to turn it off.if you leave the usb plugged in its ok ..just unplug the power from the wall socket
Jun 23, 2009 | Western Digital 320GB MyBook External USB...
My Book Essential Edition 2.0 Model WD3200H1U-00 Drivers missing
I would recommend Uninstalling and then RE-Installing the Drivers/Software. Have you looked here:
Home Edition:
Select your model here if different than above link:
Is Western Digital site for latest Driver and Software.
Let me know if this helps
Jun 10, 2009 | Western Digital My Book Essential 320GB...
USB ports on my laptop and others wont recognize my 320GB Passpor
we have to check in BIOS weather the "USB EMULATION" option is enabled or disabled.also if you have usb 1.0 and not usb 2.0 this external hdd will not be recognised.
Apr 24, 2009 | Western Digital Passport 320GB External...
WD My Book 320 Drvive not recognized via firewire conncetion
if there is softwear uninstull it and renstull if not then check to be sure the board is pluged in
Nov 30, 2008 | Western Digital My Book Essential Edition...
My Book not being recognized
try downloading updated software from western digital, install then connect!
May 12, 2008 | Western Digital My Book Essential Edition...
How to open the case of a my book wd 320gb
Try this link:
Dec 19, 2007 | Western Digital 320GB MyBook External USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
88 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
