Question about Compaq Presario 700 470024-192 Notebook
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
  • Compaq Master
  • 32,281 Answers
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 17, 2009
No bootable device
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 or, Esc key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 03, 2012 | Compaq Presario 700 470024-192 Notebook
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
My Compac Presario F700 will not come up, I just get a blank screen even in safe mode. When I press F10 it runs through programs and stops at crcdisk.sys? How do I reset system?
If you have the software disks that came with the computer you can use those to restore the system. Or use the windows installation disc to repair/restore windows.
Jun 15, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Satellite L-35-S2174 Model PSL33U-02601W Problem is Screen stays blank and Hard Drive keeps coming on and off. and nothing else happens. I changed Hard Drive thinking Hard Drive crashed, But that did not...
Go to your systems website and download the video drivers with updates for your unit. Also download a driver for your printer and install these and this should correct the problem.
Good Luck
Fehdi
Mar 08, 2009 | Computers & Internet
Blank Screen on Start Up. (Compaq Presario 700)
Unplug all external devices and then check. Go to BIOS and restore it to factory defaults
Mar 03, 2009 | Compaq Presario 700 470024-192 Notebook
Only shows compaq on screen
I work with Compaq computers now and usually your problem points to the hard drive. I know Compaq's will stay on that screen if the hard drive has failed. Try another hard drive would be my suggestion.
Hope this helps.
Mar 02, 2009 | Compaq Presario 5000 PC Desktop
My computer turns on sometimes the quickly goes blank. Other times, the On light comes on but the screen stays black and nothing seems to be moving inside.
try to desconnect or unplug your hard drive, if you see a black screen with a bunch of white letters, you hard drive is crashed, if not try to conect a second monitor (external) tru you vga connector, if work fine you have a lcd problem===>>>reemplace asap.
Dec 02, 2008 | Compaq Presario 700 470024-192 Notebook
Windows xp Install
First make sure the hard drive is reconogized in the BIO's, then do a clean install of XP choosing to delete the existing partition and install into the undefined space. choose to format the drive NTFS. if it still fails after this, sounds like you will need to replace the hard drive. Also the CPU speed will need to be at least 700 mhz for XP to work correctly but a higher mhz is all ways better. BPCS
Dec 29, 2007 | Compaq Presario 7594 PC Desktop
Compaq Presario 700 470024-192 Notebook Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
