Question about LG DLE7177 Dryer
Will not heat
LG DLE7177 dryer, 2 years old but very little use, just moved and now in use. Worked fine for 2 weeks, was using it yesterday, changed loads, and then no heat. Removed vent hose, plenty of air volume, but cold. All controls work, it runs, it even beeps to tell me load is done, but no heat and clothes are still wet. Is there a fuse on the heater element? Something I can check???
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Jul 16, 2009
Just moved the dryer to new home after having it in storage for 18 months. Plugged it in and it doesn't do anything. Tested house circuit and it is fine. Tested the dryer at the cord connection and it is...
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
as seen on heatmans blog
Apr 29, 2011 | LG DLEX7177 Dryer
We were just moved by a moving company and my dryer worked the day before they moved it. Now, my LG DLE7177RM won't power on at all. We had our maintenance come and check the outlet, that's fine, we bought...
Sounds like damage was done to the control panel during the move. You will need a qualified LG tech to test the controls and see if the power button was broken during the move.
Oct 03, 2010 | LG DLE7177 Dryer
Wont heat
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 06, 2010 | LG DLE7177 Dryer
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
Whirlpool electric Dryer has water in vent
take the vent hose out of your dryer and try to dry the clothes, if it works your dryer is fine and the vent is clogged
May 10, 2008 | LG DLE7177 Dryer
Dryer
The top comes off by removing the 2 screws in the back the hold the lid.  Push the lid back and it should come off.
Nov 10, 2007 | LG DLE7177 Dryer
LG DLE7177 Dryer Logo
293 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
