Move all the food and whatever you have in your freezer forward leaving an inch of space between the back wall of freezer and the food. This will create move air flow for circulation
Hello Craig,
DEEPEST Sympathies.
- Your DEFROST circuit is KAPUT...!!
Get out the wet/dry vacuum ... the FROST will most likely overflow your defrost pan... No heaters or heat guns... but a big fan will speed things along.
(and a big bunch of towels).
I can only talk in GLOBAL/TYPICAL terms without your make & model number... If you don't mind spending a wad of money and learning nothing in the process... you need only find a competent repair person... they will pluck off the bottom grill ... pop out the "black box" with your PCB (printed circuit board)... here-in-after we will call that your "power control board" (OR defrost timer) and either find that bad solder joint... the not unheard of WATER DAMAGE...possibly a PCB resident relay or transformer DID NOT SURVIVE...
On my refrigerator 22 year old AMANA (SBDE20S4SW which I love) that part has become quite rare (just because of time... but there are repair services that can refurbish OLD packs (10 days end to end & $100 - $195 later)... I found mine on eBay ... TURNED OFF THE BREAKER... (hazardous voltages in the area).
My CIRCUIT BOARD 12106802: Replacement fiasco:
- Wiggled out the defrost tray (took pictures with my camera)
- Unplugged the door (control panel) wires from front (took pictures with my camera)
- Took out the one ***** ("ski +rue") hold box up... and slid it (wires & all) out to work on.
- Removed one top skrew & removed box cover (a lot of wires = lots more USABLE pictures!!)
- Changed the board... (TURNED CIRCUIT BREAKER ON) worked fine...!!
- Found my bad solder joint repaired/replaced it ... (TURNED CIRCUIT BREAKER OFF/ON)
- Put old board back in...
(control lights flashing... refrigerator NOT working).
(BREAKER off)
- Took CLOSE look at pictures (found red/white transformer CONNECTORs EXACTLY WRONG... (fixed)
(BREAKER ON)... Works great!
Have spare (12106802 PCB)...
Plan on keeping it FOREVER.
Story moral: $195 later (I didn't need to spend)...
Happy happy happy.
You can make yourself prouder.
PLEASE NOTE... The "BREAKER" ... I never recommend touching ANY electronics without STATIC (ESD) protection.
A tiny (teeniest) static discharge around the MOST ROBUST electronics can destroy it... If the breaker is off... the refrigerator is still plugged in.. ergo FULLY GROUNDED... The likelihood of static discharge is quite remote... Just remember to ground your hand(s) to the refrigerator (always) before touching any electronics there-in.
Same reason all electronics are shipped in (silverized or PINK static) bags...
So get that MAKE & MODEL... check the sites below...
Any questions comment me back...
(there are two other possible reasons... but neither SMELL)
First RECOMMNDED SELLER
(appliancepartspros... same parts everywhere different $$$$)
Search Over 2 1 Million Appliance Parts
http://partssselect.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Find Your Appliance Parts
There is frost developing in freezer-too cold and cold air is not reaching the fridge below. I notice the frame under the freezer door is hot. There is a slight smell developing in lower fridge.
Warm...not really hot...going to get ice and a chest now. thanks...If I still have a problem I'll be back.
Craig, Once you get it defrosted you can use it again for a week or 10 days depending on open door time... and minimal air leaks...
