Question about Coffee Makers & Espresso Machines
Just got brand new machine and won't make water or steam (yes, water tank full and properly attached)
DeLonghi 680
    Top Expert:
  • Coffee Maker... Master
  • 63,072 Answers
Then dump the water and return it to place of purchase with receipt as defective .
Posted on Mar 27, 2016
SOURCE:
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
Aug 30, 2015 | DeLonghi Magnifica Coffee Makers &...
I just received the DELONGHI ESAM 3000 I followed the first two instructions ie. filled water tank and ensured it was inserted as far as possible (I felt that it clicks in place)., but the water tank...
Hi benjy337,
Hi i see that you are having issue with your DeLonghi Espresso Machine.
I have the link here where you can get the Manual and how to troubleshoot the the machine regarding your concern. Manual just click on ESAM3300
I read the instruction and there are two parts of the Manual the first part of the manual is A2-5732149900.pdf once you open the Manaul go to page 8 - Preparing the Coffee Maker.
I believe this will explain much further and more accurate on what you are experiencing, I would explain it myself but I do not have a machine that I can do hands onto to see and duplicate what you are experiencing first hand.
I hope that this will help you get your new machine to work properly I believe that there is nothing wrong with it.
Have a nice day,
mvincentc
Jun 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
NO WATER COMING THROUGH ALTHOUGH TANK IS FULL, AND A TERRIBLE NOISE AS MACHINE IS TRYING TO MAKE COFFE
turn unit on let it set up as norm ... when it trys to wash or even if it dont ..turn steam knob fully open until noise has gone .. all done ..oh turn steam offf... bsc appliances 07779933829 postal service too
Jan 04, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
No water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Mar 24, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
