Question about Home
Pegasus HET toilet splashes water when it flushes
Pegasus HET 1.28 toilet splashes water behind the tank when it flushes.
  • 297 Answers
Make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Posted on Jul 27, 2009
CAN THE TOILET BOWL WATER LEVEL BE ADJUSTED?
Not sure on that toilet but you can fill a water bottle with the desired amount of water and then stick it in the tank thus tricking the toilet to put less water into the bowl with each flush. If you want more water though I am not sure how to do it.
Jun 11, 2011 | Pegasus Technologies Two-Piece Round...
Not flushing, bowl will not fill up with water
Hi rjhfp
Check inside of the tank to make sure the connector from the handle of the flusher to the "flapper valve" is connected, to do this you have to remove the tank lid.
If it is connected then you have a different problem.
Sounds like you have trash in the valve inside of the "ballcock assembly"
The ballcock assembly is the part that lets the water into the tank, and the "flapper valve" is the part that allows the water to flush into the bowl...
Replace you ballcock assembly and it will solve your problems.
Free Answer...Please rate me
Apr 16, 2011 | Pegasus Technologies Two-Piece Round...
How do I lower the level of the water in the tank so I do not use as much water per flush? I have a Pegasus 2 piece toilet thats about 2 years old
Hi there terminator,
Inside the tank, directly above where the water hose is attached, is the valve mechanism. Attached to this valve there is a float.
As the water level rises so does the float. When it get high enough, the float valve shuts off the water.
The idea is to lower the float so the water is turned off sooner.
If your model has a ball on a metal arm, it is as simple as bending the arm down a little bit.
Vertical cylinder types have adjustments on them.
Then there is the simplest solution which is to put a couple of bottles full of water in the tank to take up space. Therefore less water is needed to fill it...
Best regards
Mike
Mar 05, 2011 | Pegasus Technologies Two-Piece Round...
How can we stop our 1.5 year old pegasus dual flush toilet from continually running?
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Jan 16, 2011 | Foremost Pegasus Series 1940 1-Pc White...
I have a weak flushing toilet of this model. Water does not fill tank fast enough to create the weight of water needed to start a flush. I've looked in the tank while lifting the flap and see that as the...
From your description it sounds like the flushing orifices are plugged. The orifices are the little holes around the bowl or the big hole in the throat of some. A simple way to check if this is the problem is to get a bucket with aprox 2.5 gallons of water in it and pour it directly into the bowl and see if it goes right down. If it does, the orifices are plugged. Two of the most common causes of clogged orifices are hard water deposits and bowl cleaner cakes that drop in the tank. In the case of hard water deposits, we usualy acid clean the stool with muratic acid introduced through the flush valve. Be VERY careful when doing this, as the fumes are VERY dangerous and it can discolor colored porcilyn. May want to hire a plumber to do this. As for the cleaning cakes. You can pour some tap hot water through flush valve and dig into hole with wire hanger to remove as much as possible. I hope this helps.
May 19, 2010 | Pegasus Technologies Pegasus Elongated...
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
My pegasus won't flush with enough pressure to complete it...
Maybe the shut off valve is not open all the way .....
can you adjust the fill valve so that more water comes into the tank ... more water more flush !
Dec 07, 2009 | Pegasus Technologies Two-Piece Round...
Pegasus toilet tank will not refill
Most likely the washer came off and is stuck in the shut off valve or the float is stuck all the way up. Checkk adjustment screw in the top of the water control valve to make sure it is not turned all the way in.
Sep 26, 2009 | Pegasus Technologies Elongated 2 Piece...
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Home Logo
430 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
