Question about Panasonic PT-47WX53 47" Rear Projection HDTV
RED ARCH ON LEFT BOTTOM CORNER
Panosonic m. # PT-47WX42F
  • Panasonic Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Aug 31, 2009
My Panosonic TV Model# PT-47WX42F will not turn on. It clicks like it wants to turn on but does not. The power light is flashing 5 times
5 blinks is error code for short on 140 volt line inside the set; it usually means the Horz output transistor is shorted. If you have a ohm meter (used for checking fuses etc) there is a simple test to see if this is the problem.
Also associated with this is a bad capacitor near it (Location for the Transistor is C509 and the transistor should be location Q551)
Location numbers are printed on top of board near part; both parts are on (as seen from back) far right board near the large black part with big red wire coming out of the top.
Transistor is just to the left of it and cap forward about 3 inches.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 30, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
PT-47WX42F
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
RED color wont converge with + PT-53WXD63
Dec 12, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
