Question about Dryers
Dryer will not turn on, but is plugged in. Light inside will not illuminate, either. What do I do?
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 16, 2009
  • Michael Masters
    Michael Masters Jul 16, 2009
    In your case, the most common issue here will be a defective or damaged Door pressure switch. the non illuminating drum light is a red flag and, basically, confirms that the door switch has failed.
When headlight are on and hit the beake pedal only the 3rd brake light comes on the rest are stuck . When i release brake pedal it seems like i am driving with my brake light on . but my headlight off...
It may sound silly, but check your brake light bulbs to see if they have been installed incorrectly. Brake light bulbs have two filaments, one for tail light, and a brighter one for brake lights. On some cars if the bulb is installed wrong, the brighter filament will stay on for tail lights. The only other thing I can think of is the wrong bulbs have been installed.
Dec 25, 2010 | Toyota Camry Cars & Trucks
My Whirlpool Duet Dryer Power light was illuminated but would not do anything when I pressed "Start". I tryed all cycles hoping one of them would work--it did not. I then unplugged the dryer for...
I would check the power to the dryer. Might be a loose connection. After confirming that I had power to the machine I would unplug it and check the fuse. It is located on the inside and therefore I would need to break it down, clean it up and check all of the safety's including the duct fuse. Then I would eliminate any air restrictions that may have caused the dryer to fuse to melt from overheating.themobilian_420.jpg
Dec 12, 2010 | Whirlpool Dryers
On off light wont illuminate
is it the light in the dryer?
Dec 16, 2009 | Washing Machines
I have no power on the control panel but the light works inside the dryer
I have power to the dryer. when depressing the selector switch, 20 min for example, the ride light illuminates, you hear a click sound but nothing happens
Aug 19, 2009 | Kenmore Elite HE4 Electric Dryer
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
Start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Mar 27, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
