Question about Hitachi 46W500 46 in. TV/DVD Combo
Power down malfunction
TV is going into magic focus on power down. After the magic focus finishes, it come back o without any sound and then if I try to ower down again, it brings the sound on.
  • 934 Answers
Before doing anything try upgrading the software first and see if that cures the problem. Call 1-800-HITACHI to get the latest version sent to you and then just follow the instructions. There is a port on the back of that unit where you will insert the MMC or SD card they send you and the update commands are available in the customer menu...
Good Luck!
Posted on Nov 19, 2007
Screen will not turn off
Model does not sound like Hitachi but if it is have you unplugged the set? The magic focus is a auto convergence circuit in the Hitachi sets.
Nov 01, 2012 | Hitachi Televison & Video
Power off presents magic focus screen, tv must be unplugged.
you will have to determine if tv fault or cable fault, shut down cable box and unplug it`s power cable. Once all power is removed from cable co. equipment retry your tv controls, if tv turns on correctly problem with cable co, if not tv has corrupted data (try unplugging tv for 1 minute and then retry) ifstill bad tv has bad control board or logic problem, either one will require tv tech to fix, hope this helps, video-tek
Jun 01, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Mar 18, 2008 | Televison & Video
Magic Focus does not work.
Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
with upgrade Stk394-160E Hitachi part # CZ 01341,change both
for reliability.....check B+ feed resistors for over-heating....T.
Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Ultravison Projection TV 54"
It's a hardware malfunction. It can't finish the magic focus cuz one of the IC is burned. Need to be replaced and to check the resistors.
Dec 08, 2007 | Televison & Video
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Nov 06, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Won't turn off
Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 46W500 46 in. TV/DVD Combo Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
