I put in 11x14 size paper in tray 2(11x17) but only get 8.5 inches of width printed instead of 11 inches. how do i solve this problem? thanks, joe.
  • 183 Answers
Go in [user tools /counter]=>[system settings]=>
=>[paper size settings]
Please telll me for what machine you talk about
Posted on Jul 16, 2009
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
How do I print envelopes on Office Jet 6500?
  • Flip up the printer's output tray to reveal the input tray below and remove any paper in the input tray. Insert up to five envelopes into the input tray, print-side down, and slide the width guide so it touches the edges of the envelopes but does not bend them.
  • 2
    Fold the output tray back down and flip out the extension piece at the end of the tray. Fold up the paper stop at the end of the output tray's extension to keep the envelopes from falling out of the output tray.
  • 3
    Click "File" at the top of the software program you are using to create the text to be printed on the envelopes. Click the "Properties" or "Setup" button in the window that opens, then click on the tab labeled "Paper/Features."
  • 4
    Click the "Type Is" pull-down menu and select "Envelopes." Select the "Size Is" drop-down menu and click on the size of the envelopes you have loaded in the input tray. If you do not find the correct size, click "Custom" and type the height and width in the window that opens, then click "Save."
  • 5
    Click the "Source Is" drop-down menu and select "Tray 1." Click the "OK" button at the bottom of the window to save your settings, then click the "Print" button to begin the print job.
  • Read more: How to Print Envelopes With the HP 6500 E709A ' eHow.com http://www.ehow.com/how_7439186_print-envelopes-hp-6500-e709a.html#ixzz18tq0C0JF
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 23, 2010 | HP Office Equipment & Supplies
    You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
    Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
    1. Click File , and then click Print . The Print dialog box opens.
    2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
    3. Click the Paper/Quality tab.
    4. Select Envelope as the paper type.
    5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
      1. On the Paper/Quality tab, click Custom .
      2. Click in the Name text box, and then enter a name for the custom envelope size.
      3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
      4. Click in the Height text box, and then enter the height.
      5. Click Save .
    6. Click Apply to save the settings.
    7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
    Dec 17, 2010 | HP LASERJET P1006 Printer
    IMy wife pulled the paper tray completely out of
    Loading your paper
    Paper loading tips:
    ● Load paper with the side to be printed facing down.
    ● You can print photos and documents on a wide variety of paper sizes, from
    8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
    (4 x 6 inch) photo paper is available with and without tabs.
    ● Before loading paper, pull the Main paper tray out (use the Main tray release or
    the tray grips) and slide out the paper-width and paper-length guides to make
    room for the paper. After loading paper, adjust the guides to fit close to the edges
    of the paper without bending the paper. When finished loading paper, push the
    Main tray back in all the way.
    ● Load only one type and size of paper at a time in the same tray.
    ● After loading paper, extend the Output tray extension to catch your printed pages.
    Use the directions in the following table to load the most commonly used paper sizes
    into the printer.
    Paper type How to load Tray to load
    Any supported
    photo or plain
    paper media
    1. Extend the Main tray by
    pulling it out with the Main
    tray release or the tray
    grips.
    Load the Main tray
    Chapter 2
    (continued)
    12 HP Photosmart 8200 series
    2. Slide the paper-width and
    their outermost positions.
    3. Load paper with the side
    Check that the stack of
    paper is no higher than
    the top of the paperlength
    guide.
    4. Adjust the paper-width
    inward until they stop at
    the edges of the paper.
    5. Push in the Main tray all
    the way in.
    6. Make sure the light on the
    Photo tray button is
    turned off to enable
    printing from the Main tray.
    Load paper and adjust guides inward
    1 Paper-width guide
    2 Paper-length guide
    1 Push the Main tray all the way in
    Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
    Hello sir, how to take print on A4 page? please help me
    Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
    You have the settinigs on the printer wrong. There are two things you need to do:
    1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
    2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
    Feb 11, 2010 | HP LaserJet 4050 Printer
    How do you fax a document that is 11 by 14 inches?
    Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
    If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
    Feb 10, 2010 | Office Equipment & Supplies
    Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
    In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
    The size range for custom size media is as follows:
      Minimum allowable page size:
      89 x 140 mm (3.5 x 5.5 in.)
      Maximum allowable page size:
      216 x 356 mm (8.5 x 14 in.)
    1. Open Tray 1 (MPT).
    2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
    3. When the front panel prompts you to confirm the type and size of paper:
      1. Scroll to Change by pressing the Down Arrow key and press the OK key.
      2. Scroll to the correct paper type and press the OK key to save your selection.
      3. For the paper size, scroll to Custom and press the OK key.
      4. Select Set Custom Width (W) by pressing the OK key.
      5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
      6. Scroll to Set Custom Height (H) and press the OK key.
      7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
    4. Select the custom size in the printer driver.
    5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
      • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
      • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
      Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
      • If you select Choose Specific Tray, select the Multi-Purpose Tray.
      • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
      • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
      • To create a new custom size:
        1. Click New.
        2. Enter the new name in the Name box.
        3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
        4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
        5. To exit, click Close.
      • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
      • If you create a custom size in certain applications, the driver lists the custom size automatically.
      MacOS 8 / MacOS 9 driver:
      • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
    Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
    Cannot print 11x14 paper on my Canon Pro9000 printer.
    The printing software you are using should have that size for you, I use photo gallery, after you select the image the pop-ups should be your printing software with the paper size choices.
    Sep 10, 2009 | Canon PIXMA Pro9000 Photo Printer
    jasbo
    jasbo
