Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
I have a Craftsman rear engine riding lawn mower and it runs rough in fast mode. It also misses and chokes out when mowing. It has a 13.5 HP engine. I've changed the fuel filter and cleaned the carb, but no change in status. Oil has less than 10 hours and is at correct level, Air filter has 10 hours also and is clean. Does anyone have any suggestions other that burn the thing?
    President:
  • 1,273 Answers
Hi, don't burn it. Try these two other easy things that might give you some relief: First, clean the air vent on the fuel cap. Second,change the spark plug.
Best regards, --W/D--
Posted on Jul 17, 2009
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Tractor runs crappy and then dies once i put it in mowing mode
does it run a little better with the choke on part of the way? did you leave gas in it from last season?gas is only good for about 30 days in a small engine
Apr 28, 2012 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a 13 HP rear engine Craftsman mower SP need Serial NO.
go to a crafysman tractor forum ask your question and youll get your answer.
Nov 06, 2009 | Garden
Describe your Briggs & Stratton
you need to rebuild carb and check groverner spring
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Apr 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
747 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
