Question about Jetway 939GT4-SLI-G Motherboard
Jetway 939 gt motherboard install
I purchased an jetway 939 gt motherboard and wanted to move my existing hard drive procesor etc. to it. When I put all the components on and power it up, the first time it will bring up windows and everything. When I put the install disk in and due what the manual tells me to do and restart my pc i keep on getting an error message of some exe. file or something. When I move all my components to my old motherboard i have to do an complete system restore from its original production date before it will work again. I do apolagize that I dont remember the exact error it gives me. What am I doing wrong?
  • wackerofall Aug 13, 2008
    ive tried to read your manual but it's too blurred to be of any assistance all i need is a clear pic to complete pls help
  • Anonymous Sep 26, 2008
  • 1,601 Answers
What install disk are you talking about, and sorry ,need to know the error too.
Posted on Nov 18, 2007
  • 121 Answers
Chek for RAM if installed correctly ( unplug then plug it back)
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then load system defaults exit saving changes.
if the problem still exist try to re install your os :
insert os bootable cd
hit delete or F2 to enter setup while starting computer
select boot priority or first boot device as "cd rom"
boot only 1 time from cd and then follow the installation wizard steps.
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code:
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
How to flash the JetWay 939AGP-P Bios
Get this installer programs and the Bios bin file and put them onthe desktop together and open the Awdflash exe program and fallow the instructions on this site
How to update Bios
Mar 16, 2011 | VIA JetWay 939AGP-P Socket 939 K8T800 Pro...
Jetway motherboard 939 GT4-SLI-G will only accept 3.5 gig RAM and not 4 gig RAM as per specifications. It does not run on gaming applications when 4 gig inserted (4 x 1 gig). Any solution?
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
Jan 18, 2011 | Jetway 939GT4-SLI-G Motherboard
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
It will be ok if you are going to be sure that the ordering part# correspond to this table:
Your motherboard maximum Front System Bus is 1000MHz.
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
Jetway 939 gt
what won't load, plz specify more cuz i can't understand the real problem
Feb 10, 2008 | Jetway (939AGP-OC) Motherboard
Can I use Athlon X2 procesor with this mother board?
It takes Socket-939 processors (AMD Athlon 64/Athlon 64 FX [K8]).
X2 processor used Socket-AM2
Nov 11, 2007 | PC Chips A21G Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
349 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
