LV 80 new holland
SOURCE: clutch grinds/pops out when trying to back up
Hi.There has been alot of these I've seen.Its the trans.The gears are binding up because of the bearings being worn.Its bad to say but its going to need a transmission.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: stuttering 1999 f-150 Lightning
sounds like a bad coil or coils, you should have a scanner hooked to it and watch the data stream to see which cylinders are misfiring and then check the coils or if it has wires to each plug then check the plug wires . good luck, hope this helps.
Testimonial: "thanks will try that"
SOURCE: Engine idle problem. Range Rover 4.6 HSE 1998 Have
sorry but you have tried everything i would have done except that i would have checked the engine breather pipes for deterioation like perished or soft and collapsing .you would be surprised how often this is the main cause of this sort of problem
SOURCE: does not want to start
your trottle position sensor could be going out.
I’m happy to help further over the phone at https://www.6ya.com/expert/kenneth_3efc1f8510674f04
SOURCE: 87 toyota celica gt 3s-fe 2.0 starts right up cold
Sounds to me like you have a bad air mass meter or bad map sensor.
Throttle Body Cleaning on vehicles without electronic throttle control (most 2003 and down)
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
