Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
Describe your Briggs & Stratton
I have a Craftsman rear engine riding lawn mower and it runs rough in fast mode. It also misses and chokes out when mowing. It has a 13.5 HP engine. I've changed the fuel filter and cleaned the carb, but no change in status. Oil has less than 10 hours and is at correct level, Air filter has 10 hours also and is clean. Does anyone have any suggestions other than burn the thing and take it to the junk yard?
    Problem Solver:
  • 3 Answers
Check fuel flow from the tank out of the fuel fuel pipe allso check the float level sounds like its running out of fuel then its needing fuel .at idle it can get some fuel but at fast no fuel try that mate
Posted on Sep 02, 2009
  • 130 Answers
You need to rebuild carb and check groverner spring
Posted on Jul 18, 2009
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman Briggs & Stratton lawn machine engine 6.75HP don't start no spark
Take of the hood and shine up the magneto and if that don't work the take thecarbrator of and where the primer ball is unscrew the Philips head screws and that will release the primer from the gas tank and there will be a little screan blow that out then put it all back together push the primer button 3 times the pull the cord to start the mower and it will run if that don't work then let me know if you want to get ride of it please because my hobbie is working on mowers thnks please respond back thanks hope this helps you problem
Apr 19, 2013 | Garden
What spark plug for a 19.5 hp briggs & stratton
what is the settings for the spark plug gaps in a Briggs and Stratton 19.5 engine 46 in riding lawnmower
Jul 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a Craftsman rear engine riding lawn mower and it runs rough in fast mode. It also misses and chokes out when mowing. It has a 13.5 HP engine. I've changed the fuel filter and cleaned the carb, but...
Hi, don't burn it. Try these two other easy things that might give you some relief: First, clean the air vent on the fuel cap. Second,change the spark plug.
Best regards, --W/D--
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
423 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
