Question about KitchenAid KSBP25INSS
My icemake does not make ice
Icemake stopped making ice. We noticed the filter was way overdue to replace. We replaced the filter and ice make still does not make ice. We can get water from dispenser but no ice production. We have checked to see if there is any clogged ice and also put a hair dryer to melt any clogs. Sensor is on, too. Can't figure this one.
  • 55 Answers
Hello.
It sounds like it is time to replace your icemaker. It is not requesting water and it is not going to restart once it fails. The part number is 2198597 and it is about 130 dollars. You can try to look around for a cheaper price but don't buy a generic unit. You will regret it.
Posted on Jul 16, 2009
We installed a new subzero side by side 2 years ago and have had problems with the icemake off and on. Now it doesn't make ice and the appliance center does not seem to be able to fix it. The have...
did they check the water valve?does it fill with water?all it does is the ice maker calls for water,the valve fills it,the water freezes,the cubes dump out and it fills again,most of the time it's either the ice maker or the water valve,if they changed the ice maker and the board all that's left is the valve or a broken wire somewhere in the ice maker harness
Feb 11, 2011 | Refrigerators
Icemake does not make ice
if it never gets any water then your water solenoid valve is probably bad.
Sep 03, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Ice maker doesn't produce ice cubes
put your fingers in the icemaker well to see if water is in there,if it is check your on off lever make sure it has a good clicking sound,remove the white cover from the icemake and check the gears,if you can't find anything i would replace the ice maker,your local applinace part store has them for around $50,let me know now you make out-mike
Apr 13, 2009 | Whirlpool Refrigerators
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
121 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
