Question about Vacuums
Shuts off at upright position also has lost suction. I have already cleaned the filter
  • 97 Answers
Check for a clog
Posted on Jul 20, 2009
Dyson DC 25 power shuts off in upright position
To clarify, do you mean the suction and brush motion shut off in the upright position, or that the entire unit shuts off?
If the latter, most Dyson uprights shut off the brush unit in the full upright position and shunt the suction into the handle for use with the accessories. There is also an on/off for the brush, next to the main power button for the DC25. If it's off ( or stuck that way), no brush motion. The manual also notes, 'for use, turn on power and click the foot pedal in back to recline the unit.' (Link to manual here:
http://www.dyson.com/medialibrary/files/dyson/support/downloads/uk/floorcare/manuals/DC25_Manual.pdf See Page 8). The
'High Reach Cleaning' section also notes that the brush bar won't rotate when the vacuum is in the full upright position.
If you are completely losing power, the manual notes that the unit will shut off if the bar is jammed, or if there is a significant line blockage that makes the motor overheat. If this is happening, check the accessory line in the handle for blockage.
Good Luck :-)
Jul 11, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Low suction and shuts off in upright position hose has no suction
You probably have something clogging the hose
Jan 26, 2014 | Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Upright positon dyson won't work
Have you checked your permanent filter? Have you checked the hoses for clogs. As a last resort you can disassemble the cyclone and clean it. If the vac is less than 5 years old, Dyson will probably send you a new Cyclone to replace yours.
Also check that you have the gasket inside the center of the bottom of the clear canister on the right way. If it is backwards your suction will be much less
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
May 20, 2009 | Riccar 8955 Upright Vacuum
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
positioned.
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Apr 30, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
