Question about Car Audio & Video
Hello, just a follow up on my first problem about the wiring harness for my 2007 ford expedition. i have acquired the integration Wire Harness you mentioned and it fit perfectly for the smaller plug. it has 2 blue wires and 2 RCA cables connected to the harness plug. nothing is written on the blue wires. do i just connect them to the speaker wires? and i believe the 2 RCA should be plugged into the RCA ports of my aftermarket stereo. thank you.
  • bongdot23 Jul 16, 2009
    thank you so much, so i would just leave the smaller plug in alone?
  • 2,200 Answers
Hi
No. You probably do not need to connect these wires at all for your stereo to work- just leave them blanked off.
Usually these blue wires are for one to actiavate an electric antenna and one to turn on the amplifier. Your new stereo should amplify without these being connected. If not post up a comment and let me know.
Many thanks.
Posted on Jul 16, 2009
Looking 2007 fo
Wiring diagrams shouls be available at the link below. http://bbbind.com/free_tsb.html
Mar 17, 2017 | 2007 Ford Expedition
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
I have a 99 expedition Eb and all my windows stopped working.checked fuses also bought a different window switch and now i hooked a separate ground right to battery still don't work.Any suggestions?
If fuses/circuit breaker ok..... Look for broken wires where the wire harness comes out of the door and into the vehicle. You will have to cut the rubber boot encasing the wire harness and inspect the wiring. Broken wiring is common on older vehicles as the harness flexes each time the door is opened and closed. If broken wiring found, repair as necessary
May 31, 2015 | 1999 Ford Expedition
I plugged in my aftermarket radio in my 98 ford expedition but i still get no power
According to ford truck forums online, the constant battery wire may be lite green and purple, the switched power may be pink and lite green, and the ground is black and lite green.
The battery wire is for memory.
Is that what you need to know ?
Jul 21, 2012 | 1998 Ford Expedition
Im trying to install a new radio into 1997 Ford Expedition w/premium sound. However I cannot get any sound. I have the wriring harness.
Hello... I am sorry to hear you are having a problem I am assuming that you are using a wire harness adapter to interface between your factory harness and the aftermarket radios harness. If the aftermarket stereo has a blue/white wire, you need to connect it to the blue and the blue/white wires in the adapter harness. This will turn on the amplifiers. If your aftermarket stereo only has a blue wire, then use it as the connection with the blue and blue/white on your aftermarket harness adapter. Hope this helps. If you need any further assistance, let me know!
20 year car audio/video installer
Bay manager
Mar 19, 2011 | Car Audio & Video
2004 Ford Expedition, battery draining while sitting overnight. Identified wiring harness which is drawing power while off. Harness plugs into the back of the fuse box. 5 wires in harness Orange wire,...
Start pulling fuses,one at a time,with an AMP meter in series with a battery cable. When you find anything over a few Mili Amps still on,you found the item,assuming every system has timed out. Some may take 15 min to do so. 40 Mili Amp will always be there, to power memory,clock,etc.
Sep 19, 2010 | 2004 Ford Expedition
1999 Ford Expedition brake lights
Broken power wire usually breaks at rear door harness flex point. Open outer casing & inspect for broken wire.
Sep 09, 2009 | 1999 Ford Expedition
Trying to connect a teekonsha voyager brake control to a 2003 expedition
Their should be a 6 pin conector that only 4 pins are used somtimes a 5th wire is installed for illumination, don't worrie about using that one. The connector is located in one or two different spots, the most popular place is under the dash on the drivers side just below the steering column the connector is grey. The colors are black or red / blue / green / white and sometimes a small black or brown wire is for illumination, don't worrie about that wire. Their are wiring harnasses for sell to hook the brake control through the conector, but if you do not want to buy an adapter hook the wires as followed: Vehicle Brake Control
Black or Red Black
Blue Blue
Green Red
White White
Black is power in to the brake control
Blue is the trailer brake feed
Green is brake signal
White is Ground for the brake control
May 31, 2009 | 2003 Ford Expedition
Replacing the alternator again!!!!
You have a Bad Common Ground. Check the Ground on the Battery and there is a Ground wire coming from the Alternater Wiring Harness. You may need to get a Voltometer From a Auto Supply Store and Check the Harness.
Jan 15, 2009 | 1997 Ford Expedition
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
