Question about Garden
I have a FH541V KAI engine on my 0 radious Gravely mower.The engine surges and governer bounces up and down.Compresion is good,spark plugs new,rings and valves just replaced.Adjusted carb.to best of my knolege.Please advise.Thanks Docwayne Melton docwayne@windstream.net
  • 6 more comments
  • docwayne Jul 16, 2009
    I did what you suggested + resetting the low and high speeds.Same trouble.Got a new fule pump,and blew out all the lines,but still wont run smooth unless choke is at least half way on.Hmmmmmmmm???? I'm stumped
  • docwayne Jul 17, 2009
    The fule ,and air filter are good.would adjustment of governer be advised or replaced--??
    Reciently the intake pipe was lose and exhaust I believe.I had it fixed,and they put new valves,guides,andpush rods, and it ran for about three hrs,and then other problems came up,so I took it back and thery put new rings /both sides,cam shaft/one side,and after that it started what I call lopping or surging.The trhotle bounces up and down along with the govener arm,and the only way I have found to stop the surging is to set the choke to about three quaters closed.My engine is a Kawasaki FH541KAI-I have also personaly put a new fule filter,air,and fule pump.Cleaned the carb,and put a new main jet in #112.What do you think???please advise.Thanks
    Docwayne Melton
    Did all that and still the same.
    This mower has two gas tanks,and the filling ports are aprox.31/2 in. across and aprox 6in. diamiter.
    big openings.can't see rust in caps or around openings.What about readjusting the governer arm and shaft???how would I go about it??
    The link you gave is to Brigg's and stratton/I have a Kawasaki FH541V-KAI engine.
    I own a Gravely 0 radious lawn mower with a Kawasaki FH541V-KAI engine.Had some problems ,took it to dealer,had two valves,push rods,Ring sets on both sides,and a cam shaft on left bank only.I personally cleaned the carb,put new main jet,adjusted the high low speeds,new fule pump,blew out lines and checked gas caps and even left them lose to make sure.The pilot screw doesn't seem to do any thing turning it full either way. The problem is since I got it back the engine surges or lopes with the excelator rod and governer arm together, bounce up and down,weather at idol or full open high speed.The only thing I have ben able to rectafi this is to set the choke about 3/4 closed.Delema---What do you think?? Docwayne docwayne@windstream.net
    I did all that and still same problem-Being as how the throtle rod and governer spring are together attached to the carb, and governer arm at opsit end of rod,could it be a governer problem??
    Top Expert:
  • Garden Master
  • 75,822 Answers
U HAVE A TINY PIECE OF DIRT/DEBRIS IN ONE OF THE JETS OF THE CARB, THAT IS WHAT IS CAUSING THIS ISSUE, THE CARB IS VERY EASY TO CLEAN, YOU WILL NEED COMPRESSED AIR TO BLOW OUT ALL THE JESTS AND FUEL PASSAGES, IT ONLY TAKES A TINY SPEC TO CAUSE THIS CONCERN.
Posted on Jul 18, 2009
  • 11,896 Answers
Remove and clean enitre carberator. Let it soak in solvent for a couple hours. Make sure floats are very clean. Also replacing needle and jet if necessary. Check your coil for good spark. Check air filter. You should be good.
Posted on Jul 17, 2009
  • 3,741 Answers
If the fuel getting blocked and cannot flow freely from the fuel pump to the engine it bounces.this is seen in many machines.as you mentioned fuel pump is new and fuel is good.just get the passage where the fuel is filled as there is some rust /dust in the passage where fuel is filled.clean it intternally.remove all the fuel.drain all all.clean the fuel tank completely.then get the fuel refilled and then check out iut will work. thanks.please do rate the solution.thank you for using fixya.keep updated.
  • charlymonty Jul 17, 2009
    ReAdjust the Governor. You Should Not be Able to Move the Governor Arm . Make Sure you Hold the Governor Shaft in Place Until you have the Governor Control Arm Tightened on the Governor Shaft. If you want to see the Entire Engine Diagram, go to this Linkhttp://shop.briggsandstratton.com/BShopP... and Type in your Model and the First 4 Numbers of the Type Code.
    Its Begining to Sound like the Governor Shaft Isnt on the Governor Inside the Engine. The Shaft has a Curved Arm on the Inside that Makes Contact with the Governor. If you Have the Governor Control Spring on Properly, then I would Reopen the Oil Pan and Ensure that when You Replace the Oil Pan the Governor Arm is Aligned so to Set on Top of the Governor. Hope this Helps.
  • 3,037 Answers
Change the governor spring. It needs a stiffer spring or needs to be readjusted to a new hole. Get a new one from a local dealer and confirm the hole it should be in while there since they should have a similar model on display for you to look at. Let me know how this turns out.
Benjamin
Posted on Jul 16, 2009
  • Benjamin Patri
    Benjamin Patri Jul 16, 2009
    Well if you replaced the governor spring (Make sure you use a new one, as the old one may have worn out). Then I would check the air filter and fuel filter and make sure they are clean as they are usually the cause of it if the governor is good.
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
I have a kawaski FH541V and is liking oil by the oil filter compartment, what should i do?
I would try tightening the filter or changing the filter the gasket could be bad on filter
Sep 19, 2013 | Kawasaki Engines NEW 17 HP KAWASAKI ENGINE...
How do I determine horsepower by serial number?
A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. all aa
check your engine model #
all fh641v series 675 cc 21 hp
Specs: HP cc Bore x Stroke
FH480V 16HP 472cc 68mm x 65mm
FH541V 17HP 585cc 74mm x 68mm
FH580V 19HP 585cc 74mm x 68mm
FH641V 21HP 675cc 75.2mm x 76mm
FH680V 23HP 675cc 75.2mm x 76mm
FH721V 25HP 675cc 75.2mm x 76mm
FH641V 21HP 675cc 75.2mm x 76mm 41.19 cubic inch
there must be differences in the valves and carb sizing / jetting to make engines put out more hp similar to briggs with their engines
When asked for serial, I.E. AS01, BS01, etc., the lower the letter, the newer the engine. It doesn't really matter, except for maybe spark plug reach or other subtle changes
here is good website for any parts -:
http://www.ereplacementparts.com/kawasaki-fh641vas04-stroke-engine-parts-c-30157_30211_32002.html
cheers pauly46
May 22, 2011 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Engine starts, runs rough (like cylinder missing), after a minute will run smooth a few seconds, then back to rough idle. new gas, new oil, gas filter seems clear. What else to check?
Establish which is the 'lazy' cylinder (touch the exhaust pipe header with a WET finger). There will be a marked difference in temperature. Change the plug on the 'lazy' side. If no better, check for a good spark - with engine running on the good cylinder, connect the other plug lead to a spare plug and grund the plug body. A weak/internittant spark will be readily apparant.
If there is a spark problem, replace the coil on the dud side. If not, check for equal compresion on both cylinders.
Mar 09, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Have a fh541v engine on a wright stander mower,one of the cylinder seems not to be fireing. I'v got gas and spark ? I've got compresion, value's are opening, take off plug wire no change, take off other...
my guess is the guide rods are bent . check and see if the valves are closing all the way. i just experienced the same problem on my mower
Aug 02, 2009 | Garden
Mower won't turn over
Keep it in the kitchen over night. Or anywhere that is environmentally controlled for that matter. Should start right up as soon as you get it outside.
Jan 31, 2009 | Toro Lawn Mower With Toro Power Tools
Mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Nov 26, 2008 | Garden
Garden Logo
372 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
