Thanks for the help but my ipod is stuck on hold the switch became disconnected somehow do you know how to manually turn it off hold after opening it up
  • 13,433 Answers
Did you try a reset? you will have to use the hold switch to take it off hold. if the hold switch is broken it needs to be replaced or you have to open up the ipod enought that you can manually short the pins on the switch as if it where moved to the other position.
Posted on Jul 16, 2009
Hi this has a blank white screen, clicker sounds, but no menu etc. Did sync (displayed do not disconnect etc), but now gone to all white again! Thanks
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks
Feb 24, 2011 | Apple iPod nano
Ipod classic
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 09, 2009 | Apple iPod classic MP3 Player
Locked ipod nano
Did you first slide the hold switch to HOLD and then back before holding the menu and center buttons down together? That worked for my iPod nano 4th generation after it "locked up" and became non-responsive.
Mar 08, 2009 | Apple iPod nano
My 30g ipod is stuck in the restore mode. i follow the instructions on how to restore it, and everytime i plug it into the computer, it says it needs to be restored. how do i get it out of the restore...
Try this out: And let me know the status
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then try restoring the ipod using Itunes...
Feb 23, 2009 | Apple iPod MA446LL/A MP3 Player
Apple ipod 30g blinking screen
my ipod did the same thing had to send it off and get the main board replaced not sure if that is your problem or not
Jan 04, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod gen3 nano
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
see this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Oct 21, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
My screen is locked
Make sure the hold switch is not engaged
0,0,0,0 or 1,2,3,4 twice is usually the universal
the manual will have the secret code
Jun 20, 2008 | Apple iPod nano
Help with ipod 8gb nano
Reset your Ipod using the following procedure:
Turn hold on (lock)
Turn hold off (unlock)
Hold in Menu button and middle button until Ipod shuts down and starts up again.
This should remove the lock on the Ipod.
Mar 08, 2008 | Apple iPod nano
My Ipod is frozen
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 01, 2008 | Apple iPod MA446LL/A MP3 Player
42 people viewed this question
 Grubhead
Grubhead
