Question about Sega Genesis Console
My console does not turn on - Sega Genesis Console
  • 36 Answers
Check the cabling, may have to pull it apart, and make sure everything connected together properly, also, make sure the on/off switch isn't stuck, or the switch when you pull it apart, if that doesn't work try ebay
Posted on Jul 16, 2009
My xbox turns but the image docent pop out
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
May 21, 2011 | Microsoft Xbox 360 Console
XBOX 360 - E74 WITH ONE RED LIGHT
Try first unplugging power cable to reset the unit.
Oct 19, 2008 | Microsoft Xbox 360 Console
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
Lower right hand red light flashing
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Aug 04, 2009 | Microsoft Xbox 360 Console
Can i get rid of error E 74 myself
This is from the microsoft site...
  1. Turn the console off and on. To do this, follow these steps:
  3. Disconnect all the cables.
  4. Reconnect all the cables.
  5. Turn the console back on.
  6. Turn the console off and on without accessories. To do this, follow these steps:
  7. Turn off the console.
  8. Disconnect any accessories that are connected. For example, disconnect all Xbox 360 controllers, all Xbox 360 Memory Units, and the Xbox 360 Hard Drive.
  9. When the accessories are disconnected, restart the console to determine whether the console or an accessory is experiencing the problem.
Jun 22, 2009 | Microsoft Xbox 360 Console
MY 360 HAS 3 RINGS AND WON'T WORK BUT EVERYTHING ELSE IS FINE.
THINGS TO TRY
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
If the above suggestion dose not yield results, i would use the link provided below to help fix this issue yourself.
CLICK HERE(XBOX 3RINGS FIX)
Jun 18, 2009 | Microsoft Xbox 360 Console
Xbox 3 lights blinking
THINGS TO TRY BEFORE REPAIRING THIS ISSUE
OK, if the above suggestions didn't fix this , I suggest using the link below to further dive into the repair of the 3 rings of death issue.
CLICK HERE
My xbox 360 has 3 flashing lights?
Now, if the above troubleshooting tips don't yield results, i recommend using the link below to combat this issue further.
CLICK HERE
May 22, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Xbox360
Sections 1, 3, and 4 are flashing red
- General Hardware Failure
Check the secondary Error Code per the instructions in the section below
THINGS TO TRY
Dec 17, 2007 | Microsoft Xbox 360 Console
Sega Genesis Console Logo
210 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
