Question about Dell Inspiron 13 Notebook
Dell inspiron 13 Pacific Blue: the dvd rw drive won't read any disc that is inserted in the drive. Clicked autoplay, nothing happens, click explore and it asks me to format the disc. I have had the computer for about 7 months, this has been happening over the past month. I originally thought it was my dvd burning software nothing that was burned would play, but now it won't read and dvd or cd.
I have the 2010 academic version of peachtree complete and when i put the disc in the cd-rom nothing happens. You can here the disc spinning and can my pc is trying to read the disc but then the spinning...
You computer probably has Autoplay turned off for security.
-Click the start button on the lower left and click Computer when it appears near the middle of the right column. -Look for one of the drives labeled CD or DVD, probably the D drive. Righ-click it's icon. -From the list choose Autoplay.
If Autoplay is not an option double-click on the CD or DVD drive. Look for an application called Setup and double-click it to begin setup.
May 17, 2011 | Sage Software Peachtree Complete...
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
I have a dell inspiron 530 and trying to play dvd. after i insert in the drive nothing happens. do i need to do anything else? thanks
Some computers do not come with dvd software installed.Do you have a dvd drive installed?If no software for dvd installed you can also use windows media player or realplayer to play dvds.Click start button,control panel then autoplay.Under dvd movie choose player you like to use and click save.Try inserting dvd again to check for playback.
Nov 11, 2010 | Dell Inspiron 530s Desktop Computer...
My Sony Vaio VGN-NR38M Laptop DVD+-RW/+-R DL/RAM Drive does not read any dvd's. It does not start to play, autoplay does not come up. When clicked on in My Computer, the drive says please insert disc and...
Problem in your optical drive not related your operating system.you DVD writer has a laser may be it weak.Primary you can try to solve or clean laser with cleaner CD or DVD.If you are not fix your problem,You buy a new one for your Laptop service company..
Jan 06, 2010 | Computers & Internet
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
Hp Pavilion dv6000's dvd-rw won't work
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
Feb 08, 2009 | Toshiba Satellite A135-S2386 Notebook
My NEC-6650A DVD RW (on Dell Inspiron 6000) won't read DVD ROM
mine does just the opposite. It will read DVD-ROM Games but it wont read data discs or DVD Movies.
Dec 06, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Dell Inspiron 13 Notebook Logo
231 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
