Remove the transfer belt and clean it GENTLY with alcohol (Iso-propanol preferred but Meths will work) on a cotton ball or very soft cloth. Rotate the belt as needed until all the surface has been cleaned. You may need to go round several times to clean off persistent spots. Patience is better than pressure. If spatters continue check the fusers. It is also possible that there are toner spots on the drums which can also be cleaned off with Iso-propanol on a cotton ball
SOURCE: Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
