Trying to buy xbox live and for some reason it wont work and it keeps popping up this error code.....please help me out here.
You're not having a problem with the console; you're having a problem with your bank and/or payment method.
SOURCE: Marketplace Problem
A lot of people have had this problem after the most recent spring update. If in the error message it said "can't retrieve media rights try again later" All you have to do is delete your original media rights. If not, you may have to call Microsoft for a solution.
SOURCE: do i really need Xbox live???
Hey supcom296,
If you are looking to connect two XBox consoles together for offline play, the method can vary depending on the type of XBox you own.
For the original XBox, there should be two supported methods. The first allows you to directly connect two XBox consoles together using a "system link" or Cat 5 Ethernet crossover cable, while the second is to connect up to four XBox consoles using standard networking cables and an Ethernet hub.
With the XBox 360, there should be three methods available. The first is to directly connect the two consoles using a traditional Ethernet cable (RJ45), the second allows up to 16 different XBox 360's to connect by using standard networking cables and an Ethernet hub, while the third uses either a wireless router or the XBox's built-in Ad-Hoc networking tools to make a connection.
If you are unsure how to set up the consoles using any of these methods, you should be able to find step-by-step instructions in the owner's manual for your XBox, or by simply visiting the support section of Microsoft's homepage.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: xbox live party
tell your friend to set his party to anyone and not just friends or invite only. its in a settings tab within his party options
SOURCE: Corrupted profile on XBox 360
I have heared that if you just delete the profile, just the profile, everything will be just fine (note: This only works if your profile is on xbox live).
Just go to memor, then go into the saving device the corrupted profile is on. Then "click" on the botton that says profile and delete the corrupted profile. Remember; the profile will be a small save and not taking up most of your harddrive, look for something with MB size, not GB size. When you have done this, go to "recover gamertag" and do so for the profile you just deleted. After all this, your game saves and achivements should be present and working.
SOURCE: Xbox live 80154013 error
You can only use these ways:
Directly connect it with ethernet and router/modem
Wireless Adaptor from microsoft
or this way
