Question about Samsung SGH-G800 Cellular Phone
I want to take the phone apart - Samsung SGH-G800 Cellular Phone
  • 21 Answers
Remove cover and battery and sim etc remove 4 screws that you see using a opening tool or an old sim card run it round the first seam and it will seperate. remove the centre screw and the plug next to it and remove the block by lifting up.carefully free the camera button and volume flex from there position at the side then lift the lock on the thin flex at the top of the board. lift the board from the bottom of the phone and turn it over towards the top so that you can undo the plug flex then the board can be removed the small thin flex should just slide out. next remove the six small screws off the slide part and lift that clear,then remove the two screws that hold the last plate run opening too; up the sides and the plate will free lift it out from the bottom up.whats left is the screen and camera remove and replace what you need then rebuild in reverse using new flex
Posted on Nov 06, 2009
Pantech MATRIX C740 slide hinge has come loose. How do you take the phone apart to fix? (Pantech Matrix and Duo are not the same phone)
i suggest not taking the phone apart. 5 of my friends and myself have the matrix and after flipping it a couple of times the hinges are always going to feel loose. they have felt that way on mine for over a year. and if you take it apart, the senor bars for the keyboard will go out and you will have to get a new phone or just use the number pad
Jan 10, 2010 | Pantech Matrix Cell Phone
Dropped my cell in water
does your phone still work after being submerged?? i did the same and it was toast...
the screen is layered...glasss, lcd, and they are not meant to come apart. The phone needs to be left out, taken apart as far as you can get to air out. Leave it for a day or so, and put together. Hope this helps
May 05, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Changing the LCD screen on a Samsung A-737
I had to take my sons phone apart when it got wet. I believe the screen was held in with some type of double sided tape. But you have to take the phone completely apart to get to it. I took it apart about 6-8 months ago and it is still working.
Mar 10, 2009 | Samsung SGH-a737 Cellular Phone
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
How do i take it apart?
you have to pry out the rear bottom cover with a plastic tool. that will reveal twu other screws to complete the dissasembly
Aug 11, 2008 | Motorola Mobility E815
Takin apart
do not, do not, do NOT take it apart !! :) that will void ur warranty. as it is, if u are within ur first year, take it into a store or call tech support for a replacement. if ur past a year, use ur insurance or upgrade options. charging ports really cant be fixed. but if u take it into a store with a tech, they may try to fix it, but dont get ur hopes up
Jun 30, 2008 | LG enV VX9900 Cellular Phone
Do U Know Wux Wrong. . .
special tool for taken sliders apart but sounds like the ribon for bottom end to top end might have came apart this is a dealer fix simple for them hard for the public
May 13, 2008 | Nokia N95 Cellular Phone
How do i take it apart.
using your fingernail, there are multiple plastic clips that should pop off as you run your finger around the edge, let me know if you still can't get it, you may also try a small flat headed screwdriver to pry it apart.
May 12, 2008 | Samsung SCH-u340 Cellular Phone
Cordless phone keypad problem
I too have similiar problem with Uniden phone. In my case it is only the center toggle. I indeed took the phone apart and this problem relates to the metal oxide wearing off the rubber keys that make contact with the exposed circuit lines. This same problem is common with TV remotes. Sometimes you can take apart device and find that cleaning the circuit with rubber eraser can help the problem. You can clean the rubber contacts, but be delicate as you do not want to remove the coating on the key. As far as taking phone apart? Well it helps to be a tech with experience. Usually there is at least one screw or two to remove in the battery area. Then you gently pry the phone apart. Sometimes devices like this slide apart after the screws are removed. If you pry start at position nearest where screws join parts together and work your way up. You may dent the plastic a bit in process. Once you have two halves apart be careful in next steps. There will be numerous screws holding the phone to face. Also be careful of wires to speaker. They are usually hardwired. No plug. As you take apart take careful note of how wires are routed. Also be careful of charge contacts that slide into base of phone.
I could fix my phone if I could get the part, but I suspect Uniden will not sell me the part and ask me to send phone in.
Spinman
Nov 09, 2007 | Panasonic KX-TG2336-S Phone
Cell phone disassembly
The screw is hidden underneath the plastic so you'd have to break the plastic to take apart the flipper. Not sure how you would put it back together though.
Oct 18, 2006 | Sanyo MM-7400
Samsung SGH-G800 Cellular Phone Logo
186 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
