I have been researching your problem since early this morning when I saw it first posted. It is too difficult to give you instructions for your extremely complex scenario. You will need to contact Korg, or a local music professional in your area. Korgs phone number is: (631) 390-8737
Please give them a try, I would bet it would be easy to explain over the phone with their tier 2 support staff.
Hope this helps
Tim
This system is not supported by the korg model.many users have this same problem and still cant do anything.still what functions are available in your korg model you will have to check out in the manual its a good system unit.
http://www.korguser.net/login.asp?OS=WIN&LAN=1&TOP=1
click this link and register yourself to get the free manual with all possible trouble shooting listed in .
Please do rate the solution. Thank you for using
fixya.keep updated. thanks
https://www.korguser.net/Asp/New_Custome...
click thois link and check out for new users fill the details and continue in the link.
keep updated.thanks.
I'm trying to setup a Korg 168, I recently purchased, the Korg MODES, are as follows:PROGRAMS, 00-Preset PGM, 01-Record ADAT, 02-Mix ADAT 1, and 03-Mix ADAT 2, there's also, 04-Cassette Master (DAT), 05-Cassette Sender (DAT). MODES: MISC, Clock Source, SOLO MODE. External Bus, with Master L & R, Solo L & R, E1 & E2, A1 & A2, G1 - G8. (On & Off switches). Input/Send/Pan, with Input, (Digital or Analog), Aux 1 & Aux 2, Eff 1 & Eff 2, along with Pan, (POST are also included). EQ In, (PAD), Low, Medium, High Frequency, BUS, Master, top (On & Off), G1 - G8 (Bottom, with On & Off switches, next is Input 1-16, (Digital In A1 to A8, B1 - B8, OR Analog A-H. BUS MASTER, G1-G8, Group Master, G1-G8, with On & Off switches, Group Level, G1-G8. SEND MASTER, SOLO, L & R, POST, AUX 1 & 2, (On & Off), Eff1 & Eff2, (On & Off), Monitor Master, (On & Off), Aux 1 & 2, (On & Off), Eff 1 & 2, (On & Off), Group Link, (On & Off), G1-G8, (On & Off), METERS, Group, Solo, Aux & Eff, CHANNEL METER, A1-A8, B1-B8, Analog A-H. EFFECTS, 1&2, EDIT, Type, AUX SEND, 1-16 and finally, EFF SEND, 1-16. I'm trying to MIXDOWN a few tracks and I would like to KNOW, which functions I need to activate in order to MIX to ADAT, Program 02&03, followed by, Program 04, Cassette Master, (Mix down to DAT Recorder).
I'm trying to setup a Korg 168, I recently purchased, the Korg MODES, are as follows:PROGRAMS, 00-Preset PGM, 01-Record ADAT, 02-Mix ADAT 1, and 03-Mix ADAT 2, there's also, 04-Cassette Master (DAT), 05-Cassette Sender (DAT). MODES: MISC, Clock Source, SOLO MODE. External Bus, with Master L & R, Solo L & R, E1 & E2, A1 & A2, G1 - G8. (On & Off switches). Input/Send/Pan, with Input, (Digital or Analog), Aux 1 & Aux 2, Eff 1 & Eff 2, along with Pan, (POST are also included). EQ In, (PAD), Low, Medium, High Frequency, BUS, Master, top (On & Off), G1 - G8 (Bottom, with On & Off switches, next is Input 1-16, (Digital In A1 to A8, B1 - B8, OR Analog A-H. BUS MASTER, G1-G8, Group Master, G1-G8, with On & Off switches, Group Level, G1-G8. SEND MASTER, SOLO, L & R, POST, AUX 1 & 2, (On & Off), Eff1 & Eff2, (On & Off), Monitor Master, (On & Off), Aux 1 & 2, (On & Off), Eff 1 & 2, (On & Off), Group Link, (On & Off), G1-G8, (On & Off), METERS, Group, Solo, Aux & Eff, CHANNEL METER, A1-A8, B1-B8, Analog A-H. EFFECTS, 1&2, EDIT, Type, AUX SEND, 1-16 and finally, EFF SEND, 1-16. I'm trying to MIXDOWN a few tracks and I would like to KNOW, which functions I need to activate in order to MIX to ADAT, Program 02&03, followed by, Program 04, Cassette Master, (Mix down to DAT Recorder). The site (link) was for registered clients only.
