Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Have a Whirlpool Model LLR7144DQ0 - top load 7 cycle heavy duty large capacity. Stopped agitating - only turns slightly with tub - Help!!
jsrock516
  • 5911 Answers
SOURCE: Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Posted on Jan 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 1218 Answers
SOURCE: I have a heavy duty large capacity Whirlpool
Good day,
Common problem. The top of the agitator is driven by what are called "dogs", and are worn out.
Here is an excellent tutorial on how to replace them.
The cost should not exceed $10.00.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Thank you for using FixYa
Posted on Dec 29, 2009
  • 572 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Posted on Feb 12, 2010
  • 4340 Answers
SOURCE: Whirlpool heavy duty super capacity plus washer
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Posted on Jan 22, 2011
Testimonial: "Thanks! Both the Drive Coupler and the Agitator Dogs are Bad. ( Hope It's not a Transmission problem as well)"
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I'm just a tentant asking a question before calling maintenance. Is the agitator suppose to only turn in one direction? I thought it was suppose to be a back and forth movement. This model is a...
You have a 2 part agitator.
The bottom portion moves back and forth. The upper corkscrew moves clockwise only,pulling the laundry down and around the tub.
Jul 21, 2011 | Estate ETW4400VQ Top Load Washer
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 22, 2008 | Whirlpool LSR6232J Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
380 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
