Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony KV-27FV310 I have recently added a DVD Player/Recorder to my setup. It is connected directly to the TV via the component inputs. Problem: any video source that is connected to the component inputs on the TV are not available via the TV's Monitor Output jack. This does not seem normal. All other video input signals (s-video and yellow video input) come out through the Monitor Output jack. Any advice on this problem appreciated.
  • 1,694 Answers
Re: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
0 characters
3 Points
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cannot connect DVD player
Have you connect all the component video out cables from DVD to your WEGA TV? if so just set your tv to dvd input.
Jun 01, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Jan 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Nov 03, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
Sep 05, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
152 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
