If you can see where it attached to, usually something that is controlled with a rod like a deck lever or blade engagement, brake, what have you, there will tend to be a threaded straight end of the rod for slack adjusting and a smooth, "L" shaped opposite end with a hole through it. Look for a hole wherever the L end was attached, it'll usually have wear and an oblong look to it from hundreds of uses. Put the L shaped end through it, put a washer on the end that protrudes, the one with the tiny hole, then put the correct sized hitch pin clip through the hole past the first bump, but not all the way to the 180 degree bend. The washer is to help with wear, you can also put another washer between the L bend in the rod, and wherever it does, plate or whatever, so that piece isn't overly worn or distorted by the rod, only the sacrificial washer is eventually destroyed and then easily and cheaply replaced. Good luck.
Remove the center console covering the parking brake lever. Locate the parking brake lever between the drivers seat and the front passenger seat. Put the parking brake lever in the lowest position.
Turn the cable adjuster locknut to make the nut loose. Find the nut at the base of the parking brake lever.
Raise your GT rear wheels using a jack and support the rear wheels using jack stands. Remove both rear wheels using a tire iron to loosen and take off the lug nuts. Take off the tire from the rods by hand.
Get underneath the car and remove the rubber hole plugs from the brake rotors. Locate the rotors on the underneath inside of the wheel wells.
Take off the brake calipers with a screwdriver, but do not disconnect the brake fluid lines.
Use a pry bar to push up on the parking brake self adjuster wheel. Locate this next to the brake caliper and it looks like a star wheel. Rotate this wheel until the rotors will not turn.
Turn the adjuster wheel five notches in the opposite direction. Reinstall the calipers and wheels. Lower your GT using the jack and remove the jack stands from the rear wheels.
