Okay I turned off our 2400 lexmark and when I went to turn it back on a thin strip gray colored and about 1/8-1/4 wide with arrows at each end where does this go?how do I fix it can it be fixed?
    President:
  • 2,306 Answers
If the holes on the end are not torn, The arrow points up and it threads thru a hole above and behind the ink carts, it connects with a spring on one side and a hook on the other.
Posted on Jul 16, 2009
When i opened my lexmark 1200 printer to replace the ink cartridges, i noticed a long thin strip of plastic was loose. and now the cartridges dont move back and forth smoothly but clunk to either side and...
If the encoder strip has become unseated: 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover. 3 Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer. 4 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back. 5 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 6 Reconnect the power supply and turn the printer back on
If you need some graphical reference, please refer to this article: Printer Cartridge Stalls or Is Blocked .
Apr 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Wont print, slams back and forth at high speed
dirty encoder strip or paper at ends....encoder = thin 1 cm wide plastic strip width of printer parralell to shiny scanner rail..clean it with metho n rag gently!
Oct 11, 2009 | Lexmark Z715 InkJet Printer
Indicating a carrage problem, carrage going to fast and slaming into one on start up
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
try this printer self-test by following the steps given below:
1. Please press the "Options" button 10 times. "Cartridges" should now appear in the display screen.
2. Press the "Left Arrow" button once, which then brings you to the "Self-Test" option.
3. Press the "Select" button once. You will hear a series of clicks.
4. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about ½-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK 7350 IS NOT WORKING
HI,
Please follow the instructions given below to know exactly when the light is blinking:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
Dec 28, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Bulb failure pasrking light
Taillight bulb needs replacing, high above brake light at approx height of bottom of side widow.
Remove plastic panel at interior rear corner, remove thin backing insulation and reach up with fingers between metal flanges. Feel for a plastic "fin" approx 3" long x 1" wide that is attached to lightbulb. Similar "fin" for brake light is visible (white color). You need to feel above this. Fin is probably gray color, but you can't see it. Twist slightly counterclockwise and pull out. Bulb is attached to end of "fin". Insert new bulb and replace.
Nov 08, 2008 | 2002 Volvo V70
A THIN plastic strip about 1/4 X 16 INCHES LONG HAS BECOME SEPRATED FROM MY X4270 PLEASE ADVISE HOW TO FIX
This clear plastic strip is responsible for telling the print head where it is horizontally. Pls note that it has black stripes almost like bar codes. Both ends of this encoder strip normally would have holes for hooking up to lock tabs on both ends. What is important is that this strip is embedded in a slot at the back of the print head that reads the bar codes/locations.
This page may shed additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
Lexmark P4350 problem, anyone have a service manual?
Its the encoder strip if come out from one side ur printer is defective it cannot be replaced back..if it is out its position please
Use this link to trouble shoot:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:479:0:0&framed=&docid=ENUS22722&relevance=0
Mar 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark 5070 printer broke again
its a lexmark, i had one at one time and learned the best solution to problems like this is to find the deepest well and through the thing to the bottom. go buy a HP all in one printer, its worth the money and will ease off the headache.
Dec 10, 2007 | Office Equipment & Supplies
21 people viewed this question
k24674
jasbo
jasbo
